xs1100 wire or tube out of top of starter?
  • Eastcoaster
    • Jan 2012
    • 508
    • oceancity NJ
    Working on my new find 79xs1100 What would this be it is above the starter cover a wire, or a tubing? I touched it snaped like a twig. Where does it go?
    Looked through service manual no luck
    82 XJ1100J
    81 Venturer
  • Eastcoaster
    • Jan 2012
    • 508
    • oceancity NJ
    82 XJ1100J
    81 Venturer
    • James England
      • 3039
      • North of England
      You need to be more specific than that. It's better if you can post a photo. If you are referriing to the black wire which is actually attached to the starter motor, then I doubt it would snap like a twig. Is it a tube? ie hollow? Or a wire with cable in the centre?
      • Eastcoaster
        • Jan 2012
        • 508
        • oceancity NJ
        pix posted
        pix posted I am still learning Thanks as shown is how I found it on the bike the top was not connected to anything it cracked more when I moved it
        82 XJ1100J
        81 Venturer
          That's a wire, and it's supposed to go to your oil pressure switch (which would be to the right in the pic just out of sight behind the carbs)...
            Exactly right Steve. The oil pressure switch wire runs down under the starter motor and comes out the slot in the starter cover. It plugs in behind the fuse box.
            • Eastcoaster
              • Jan 2012
              • 508
              • oceancity NJ
              the wire
              Would that explain the red wire attached to the cable going to the sensor center rear of the head? but ti follows up under the tank?
              82 XJ1100J
              81 Venturer
              • Eastcoaster
                • Jan 2012
                • 508
                • oceancity NJ
                82 XJ1100J
                81 Venturer
                • Eastcoaster
                  • Jan 2012
                  • 508
                  • oceancity NJ
                  heres the bike
                  82 XJ1100J
                  81 Venturer
                    Is there a guage mounted somewhere?
                    • Eastcoaster
                      • Jan 2012
                      • 508
                      • oceancity NJ
                      No Guages
                      no guages all stock except the strange light under the headlight?This red wire runs from the sender switch up under the tank I have not traced any further No oil lights are on? I can trace it further
                      82 XJ1100J
                      81 Venturer
                        It probably is bypassing the wiring harness for some reason and goes directly to the plug to the oil light in the dash.
                        You need to investigate that.
                        That strange light is just an auxillary driving light it looks like.
                        • Dragon Tamer
                          XStremely XSive(Deceased)
                          • Sep 2006
                          • 426
                          • Half way between Chili and Winter Wisconsin.
                          With the wire in that condition it was most likely bypassed because it was shorting to ground and causing the oil pressure light to come on. Very common problem.
                          The Old Tamer
                          _________________________
                          1979 XS1100SF (The Fire Dragon)
                          1982 650 Maxim (The Little Dragon)
                          another '82 650 Maxim (Parts Dragon)
                          1981 XS1100SH (The Black Dragon)
                          If there are more than three bolts holding it on there, it is most likely a very important part!
