ok, so i got the starter to turn over today and there was air coming out of the mufflers. i finally got around to checking the pressure on each cylinder, and nothing. i assume i'm checking correctly (taking one plug out and then screwing in the gauge then turning the motor over) i thought of a couple things, then i decided to check my gasket kit to see what gaskets are left over. sure enough, the gasket that is for the camshaft/timing chain opening was never installed (i feel like an idiot
) so i thought about it some more, and wouldn't i still get some kind of pressure since the rest of the motor is covered up and the headers/mufflers are on? wouldn't the needle at least move some? so is the gauge broken or is the camshaft gasket what is causing the problem? i inspected the pistons and cylinders previously, and they were in great shape.
If you have even weak preasure it should blow your finger loose. Check all cylinders and see what you have. If it blows your finger out and the guage does not register more than 60 PSI I bet its broke or the release is stuck.
