uh oh!
  • Nubian
    • Apr 2011
    • 467
    • The Big East
    uh oh!
    Well.... I was feeling real good about finally syncing the carbs. Then I decided to fine tune as I thought it was running a little rich because of the exhaust. Well I went to turn out and found that all the needles were seated except for #1. Now all the pipes are barely warm to the touch except for #1.
    What damage did I do?
    BAMN!
    '81 XS1100H "Brutus"
    Damage? No damage, except to your free time!
    Turn the pilot screws out 1.5 turns to start with, then resynch, and then retune, you should get all 4 pipes getting hot then.
    • Nubian
      • Apr 2011
      • 467
      • The Big East
      I was once advised not to run the motor too lean for too long because it could damage the motor. And since I was having a hell of a time with synch/tune coupled with the fact that I found oil in the plugs, no vacuum in #3 and luke warm pipes and this neophyte ASSumed the worst.
      Have now discovered a couple of vacuum leaks, low settings on #'s 3&4.
      Will take care of leaks and start anew, feeling better now that I think I know what I'm doing.
      BAMN!
