What are these off of?
    I just picked up another a parts bike last week and these are the carbs that were with it. I don't recognise them. They are Mikunis but a bit different from the XS carbs.
    They look like late (80-81) carbs but there aren't enough vent holes on the airbox side and there is only one bowl vent, like the two on the early carbs but right in the middle and they have the thick diaphragm caps like the early carbs but the mixture screws are sealed like the late carbs. And, there isn't a choke lever on the side it's set up for a cable.
    With bowl drains, definitely not 81 or later carbs. Other than that, I'll guess with ya.........
      Greg, that 'bowl vent' looks like the fuel feed to me, and are the slides missing? Other than that, I don't know any more....
        Now that I look at it your right Steve. I was looking at them upside down and thinking that way too.
        Still, 1 fuel feed in the center and the other differences I mentioned?
        What the heck are these off of?
        Whoever had this when it ran had it set up as a bagger. It's an SG but it has a 78 engine (which I was told was locked up but isn't) the number on the case is 2H7-001904. A REAL early one.
        Somebody did some work on this thing.
          Mikuni sold carbs to all comers, so the only thing that's for sure is these are off an inline 4. But I recall seeing some Suzuki carbs with a single fuel inlet, so maybe something from that family?
          • SFerinTEXAS
            • Jun 2006
            • 877
            I also knew that the gs BS34 had center feed fuel, occasionally wrongly listed as xs carbs on ebay.
            Found this and the intake looks the same as yours.Dunno.Maybe ,T in tx
            79SF
            XJ11
            78E
            • GNEPIG
              • Apr 2005
              • 1657
              • fl
              Late 70s Suzuki.... (good guess Steve)
              • GARTHXS
                • 1631
                • Seattle
                Do the slides have a concave . They might be bs36 off an fj11 that's what I have and they are sweet
                91 kwaka kz1000p
                Stock
                ( Insert clever quote here )
                • petejw
                  • 2269
                  • sydney australia
                  hey greg,
                  they look similar to a set of carbs that
                  came off 1 of my parts bikes, they were off
                  a suzuki, the ones i have, have 4 holes in the back
                  of the carb bell tho, the fuel bowls look the same.
                  does it have a vac port on the 2nd carb?
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  1981 xs1100 RH (aus) (5N5)
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                  • Dragon Tamer
                    XStremely XSive(Deceased)
                    • Sep 2006
                    • 426
                    • Half way between Chili and Winter Wisconsin.
                    Greg,
                    They look very similar to the spare set of carbs I have for my Maxim. The float bowls are a bit different but the ones between the spare set and the set currently on the bike are different too. But the Maxim used a cable controlled choke and a single feed and the intake area is identical.
                    The Old Tamer
                    _________________________
                    1979 XS1100SF (The Fire Dragon)
                    1982 650 Maxim (The Little Dragon)
                    another '82 650 Maxim (Parts Dragon)
                    1981 XS1100SH (The Black Dragon)
                    If there are more than three bolts holding it on there, it is most likely a very important part!
                      Originally posted by petejw
                      hey greg,
                      I actually didn't look Pete, I'll look when I get home.
                      Originally posted by Dragon Tamer
                      Greg,
                      I was kinda thinkin' that too Gary but don't the XJ carbs have the thin stamped steel cover on the diaphragms?
                      • Dragon Tamer
                        • Sep 2006
                        • 426
                        Greg,
                        My one set has the stamped steel covers the other has aluminum.
                        The Old Tamer
                          Ok, they do have the vacuum port on the #2 carb but it sticks straight up rather than coming out at an angle like XS carbs.
                          • foreda
                            • 949
                            • Southwest Louisiana
                            Suzuki GS 1100
                            GS 1100 is my guess.
                            78 XS1100E Standard
                            Coca Cola Red
                            Hooker Headers
                            1979 XS1100 Special
                            1980 XS Standard
                            2006 Roadstar Warrior
                              Does the GS have the vacuum port?
