Hello everyone, first off I would like to say thank you for keeping this site going. Last January I bought a 79 xs1100F not running with all sorts of problems. Going through your posts and tech tips I was able to clean the carbs, twice, go through the brake system, adjust the clutch and I can't remember what else.
At the end of last year the turn signals started flashing really slow for a few days maybe a week and and eventually the whole bike died while sitting at a traffic light. I'm finally getting the time to work on it. I've had the battery removed but I noticed when I hook it up the main fuse gets very hot. The headlight is the only thing that comes on. I'm also pretty sure this had something that controlled the light to only come on when the engine is running and that has been bypassed. I've tried to find a broken or shorted wire but haven't found anything. Also, when I remove the turn signal flasher the fuse does not get hot anymore but still no power except to the headlight. Does that mean the short is between the flasher and a light bulp? Any ideas? Is there something that could have gotten burnt up because of the short?
I also think I should add that this bike originally had a yamaha fairing and hard bags just like a venturer model. I bought it without the fairing on and there was no bracket so I just got a cheap headlight and turn signals and I removed the hard bags because I didn't think it looked right with them. I would like to mount both back on the bike. Any ideas where I can get a bracket for the fairing? Already check ebay every once in awhile. I was going to add pics but I'm not sure how.
