Young kid = stupid question..
  • Pancala
    • Jan 2012
    • 67
    • Shawnee, OK
    I have been getting good progress with my XS. New tires, put in the new fuseblock, rebuilt back caliper, wheel bearings done all around and many others.
    The problem I'm having is putting the rear brake caliper back on, when I bought the bike it didn't have one so I have no knowledge of taking it apart, hence, I cannot for the life of me get it put back together. I'm afraid to push the piston in any further. Wrong pads?(ordered from newmotorcycleparts.com), wrong setup? Missing parts? Wrong technique? Or just young kid new to motorcycles? Haha. I looked at the clymer manual and the service manual with little help. Pictures are very welcome!
    Any help would be greatly appreciated!
    1980 XS1100SG(First bike, sold)
    Other bikes
    1976 Kawasaki KZ400 (project)
    1983 Yamaha XV920 Midnight Special
    1984 Yamaha XT250 Enduro (project)
    That caliper piston should squeeze in farther.
      • 3193
      Which XS would you be working on? There are many differences between models even if they be small.
      • soccer4m
        • 694
        easy
        Hey Young guy,,,,take a c clamp or big channel locks and squeeze the piston until it bottoms out. There is no problem by moving the piston in until it almost lines up with the rim of the caliper. If it doesnt go semi easy the caliper could use a cleaning. To make the piston move much easier when squeezing, just loosen the bleeder a few turns and let the fluid squirt out when squeezing. This should give you enough room to slide right over the pads and put back over the rotor.......I also put a small rag on the piston when squeezing to keep the clamp from scratching the piston edge...........have fun, Mike in Sun Diego
        mike
        1982 xj1100 maxim
        1981 venture bagger
        1999 Kawi Nomad 1500 greenie
        1959 wife
        • Pancala
          • Jan 2012
          • 67
          • Shawnee, OK
          It is an 80 sg model
          Thank you for the tip, I was afraid pushing the piston in any farther would unseat the rebuild kit I just put in. It was enough of a pain trying to get it back in there. So we'll sum it up to a young kid not knowing much
          Other bikes
          • SFerinTEXAS
            • Jun 2006
            • 877
            Except for the lh and xj that caliper is the same for all the rest I believe. Nate's right it needs to push in all the way.
            79SF
            XJ11
            78E
            • petejw
              • 2269
              • sydney australia
              dont be afraid of pushing the piston back into the caliper,
              thats what u need to do to have it fitted with new pads.
              dont know what happened there, there was no replys before i posted lol
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • ddragon63
                • Jan 2012
                • 1101
                • Ridgefield, WA
                +1 You can also just loosen the master cylinder cap so when you push it in the piston the fluid goes back up into the cylinder. loosening the cap will keep it from over pressurizing. C-clap and an old pad against the piston so you don't accidently crack the piston. If you place the old pad in the mix it will push the piston back to flush with the pad backing plate. Works for me YMMV
                Don
                old:
                1989 kawi ex500
                1996 yzf-r6
                1999 yzf-r1
                2001 kawi zx-6r
                2000 Ducati 748
                2002 YZF-R1
                2005 V-Star 1100 Classic
                • ddragon63
                  • Jan 2012
                  • 1101
                  • Ridgefield, WA
                  BTW there are no stupid question... well not really if you don't know its not stupid, and its smart to ask. Brakes are not something most people tackle every day. Good luck with your project.
                  Don
                  old:
                  1989 kawi ex500
                  1996 yzf-r6
                  1999 yzf-r1
                  2001 kawi zx-6r
                  2000 Ducati 748
                  2002 YZF-R1
                  • petejw
                    • 2269
                    • sydney australia
                    jat,
                    dont forget to pump the pedal a few times
                    after u have everything back in place and put together
                    otherwise ur first outing might not be a pretty one.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                      Hold your horses....
                      First, did you thoroughly clean the internal groove in the piston bore before you installed the new seal? If that wasn't spotless, go back and do it again. Crud in the groove will cause the piston to go in hard and not move correctly. Next, did you verify the piston would go in and out of the bore smoothly before you installed the seal? Any burrs, corrosion in the bore will be more trouble soon. Same thing goes for the outer piston surface; it needs to be smooth and pit free. Next, seat the outer seal on the piston first, then push it into the bore; this will make sure the outer seal is seated properly. You can install the outer clip after the piston is in.
                      Lastly, that's not the correct way to install the pads. You're supposed to remove the caliper bracket from the bike, install the pads on the caliper, slide the caliper into the bracket, then install the assembly back on the bike. Note there's a pad retaining screw on the inside of the caliper; if this isn't installed (firmly holding the inner pad in position), the anti-rattle spring will cause misalignment and cause the rubber bushing that the caliper slides in to wear out.
                      • XJkid
                        • Jun 2003
                        • 281
                        • Elk Grove, Ca.
                        Originally posted by petejw
                        jat,
                        Yeah, I did my van and forgot to repressurize, put it in drive and took out a shelving unit in my garage
                          That would prove to be difficult on the rear brake, the axle would have to come out. Much easier putting the pads in the bracket then putting the screw in from the other side.
                          • BigRed
                            • Mar 2010
                            • 265
                            • Ottawa, Ontario, Canada
                            One more thing... did you lubricate the seals and pistons with brake fluid? If you're pushing it in dry, it'll get stuck and your brakes probably won't release properly.
                              Yep, the axle has to come out. The FSM is ambiguous about this procedure for the rear brake, but my personal experience is the pad retaining screw can be a bitch to install in the rear with everything mounted. With the cast caliper bracket disengaged from the rotor, you can make certain everything is lined up right...
