Compression test
  • mack
    • 2411
    • Ontario, Canada
    Compression test
    I saw a post that said to unplug the four pin connector from the TCI. Why?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Prevent it from starting or even attempting to fire the coils.
      It's to prevent the coils getting power, and if they're not connected to the plugs or grounded to the motor, you can damage the coils or the TCI....
      With the pick-up coils disconnected, the TCI thinks the motor is 'off' and shuts itself down. I usually unplug the larger plug, that disconnects all power from the ignition.
      • mack
        • 2411
        • Ontario, Canada
        Thanks good to know
        I,be never done that before but I'll start now. Checked the compression (cold) on Spica today and got 135,135,135,142.I'm pretty happy with that considering how long this bike sat. I'm sure they'll come up with some milage.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
          Since spec is 142 +/- 10%, And that was cold, I'd say your in fine shape as is!!
          • mack
            • 2411
            • Ontario, Canada
            Riding
            Well she sure runs good. I've been out on her the last two days and it's amazing how smooth she is through the power band. Roads still have fine sand on them from the winter maintence making the grip tentative at best but I've managed to red line her twice in 4th(checking clutch adjustment), she rolls through the entire tach without any hesitation. Still doesn't have the snap of the SF, but still pretty impressive. This bike sat for almost 22 years after the original owner died suddenly. Two people had it after that but couldn't get it to run or ride properly. They only managed to put 200 miles on it, while in their possesion. Man am I glad. It looks and runs like they do coming off a show room floor.
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
              That 81 won't ever have the snap of the 79. After 79 the compression went down, the cams got a lot milder and the carbs got the EPA workover too.
              They tried to compensate for the changes with larger valves and it worked pretty well but it still won't have that thrill factor at 3.5-5K.
              • mack
                • 2411
                • Ontario, Canada
                For sure
                i noticed that right away. The SF has a definate pucker factor you have to set up for when the mains kick in. This one is still strong but much smoother. Just doesn't have that turbo effect when you roll on the throttle. I still like it but, the SF is still my original and favourite of the two.
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
