puting on an ebay head guy didnt mark valve buckets
  • 1fasttrucker
    • Jun 2011
    • 77
    • Mason, Michigan
    hi guys I have bought a used head and cams off ebay for my 79 special every thing checks out , but the guy pulled the valve buckets and didnt mark them , should i install the buckets and cams and use the fealer guages and move pucks around untill I get the valves to specs???
    any ideas or help would be great thanks , ken
  • ddragon63
    • Jan 2012
    • 1101
    • Ridgefield, WA
    ya that's about the only way I can see to do it. make a map of what puck you put where. and start playing musical chairs with them.
    Don
    old:
    1989 kawi ex500
    1996 yzf-r6
    1999 yzf-r1
    2001 kawi zx-6r
    2000 Ducati 748
    2002 YZF-R1
    2005 V-Star 1100 Classic
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      buckets
      You can do all this preliminary adjustment with the head off the bike and its much easier to do but make sure and only put one cam in at a time. If both cams are in and you do not rotate in proper time the valves will hit and bend eachother. Make sure the valves have a clear path as even having a valve lifted and the weight of the head on it can deform them. When installing the buckets before you put the keepers in rotate the buckets and make sure they rotate freely. If they were not in the head they may have been sprung. If they drag it can stop the valves from rotating and make it more prone to burning valves.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      Barnett Clutch Springs
      R1 Clutch Fiber Plates
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
        You may have already thought of this or done it, I would lap the valves for a good seat first, then sit the head up on bricks or wooden blocks to make sure the valves have room to open and close. And yes, one cam at a time.
        Of course it is best to keep the buckets and valves in the correct cylinders, but if they were not marked, you have no choice but to roll the dice and move shims to get the right clearances.
          • 5069
          Ebay! Yeah, I bought a head from ebay that was supposed to be complete with cams, valves, etc. This was supposed to be from a good running bike. The guy put in a valve that was the right diameter, but the length to the keepers was just a bit too short (from a different model/make of bike). He said he would pack it well and the damn box was ripped open from the studs. I complained and he called me a crybaby!
