Possible broken carb post repair
  • WSL91
    • Feb 2012
    • 427
    • Quad Cities, IL
    Got a line on a possible post pin repair product for the carbs. It may or may not work on the Yamaha carbs but certainly starts me thinking. The site is a Honda site but their bikes share some commonalities with ours, within minutes I found some great carb rebuild tips.
    John
    http://www.randakks.com/Float%20Pivo...pair%20Kit.htm
    1970? Honda Z50... gone
    1974? Yamaha 100 Enduro... gone
    1974 Honda CB200... gone
    1981 Yamaha Virago 750... gone
    1993 Honda Shadow 1100... gone
    2008 Honda VTX 1800F
    1982 Yamaha XJ1100J w/850 final, Raptor ACCT
    1979 Yamaha XS1100SF "Chewey" Raptor ACCT
    http://www.johnsoldiron.com
  • clcorbin
    • Jan 2010
    • 495
    • Albuquerque, NM
    I broke the top off one of my posts last year (or the year before, I forget...), right along the hole for the float pin. I glued it back together with JB weld and it held for about a year or so before it started to get loose.
    Having access to a machine shop, I took the carb in and made a new post out of aluminum and then machined the broken post flat and drilled a hole in it to fit the new post. I machined a reduced section of the new post to be a 2 thousands press fit into the socket on the carb and pressed it home. A bit of work with a file produced the flats and other geometry required by the float. I just had the carbs off today and the replacement post is still working perfectly.
    -- Clint
    • Joab
      • Aug 2010
      • 472
      • Ozark, Alabama
      So....can I just send you my carb with the post that managed to snap in two spots to be fixed?
      Joab
      "If nothing else, it will be interesting..."
      ______________________________________________
      1979 XS1100SF
      1972 XS2 650
      Ozark, Alabama
      • mharrington
        • 407
        • Holland MI
        That kit is very handy and creative. A member here fixed his with a section of bolt. I have mine wire tied.
        • clcorbin
          • Jan 2010
          • 495
          • Albuquerque, NM
          Only if you don't mind it going onto the end of my standard queue. That means it should be done some time before the second coming...!
          -- Clint
          • Joab
            • Aug 2010
            • 472
            • Ozark, Alabama
            Hey, that should be just around the same time I get this thing running like an actual motorcycle again!
            Joab
            1979 XS1100SF
            1972 XS2 650
            Ozark, Alabama
