More PO woes
  • Titbit21
    • Feb 2011
    • 76
    • Kent, Ohio
    More PO woes
    Last summer I had a petcock leak, so I ordered a rebuild kit from george fix. Yesterday I disassembled my petcocks only to find out they are not the original, or even for a xs1100 from what I can tell . So the rebuild kit I have is useless. So I was wondering if anybody would have an idea what these are meant for.
    I also don't know if I should order the original petcocks or find a kit for these. I also had problems with the carbs overfilling last summer and getting into the air box. Could this happen because of the wrong/leaky petcocks. I set the floats on the carbs a few times and the problem still exist. Any Ideas would help, Thanks
    '78E
    The overflowing of the carbs is from the float needle valves not seating properly. You need to address those first.
    No idea on the petcock issue.
    • XJfan1
      • Feb 2012
      • 180
      • Huntington,Indiana
      I was helping a friend reinstall his tank after a paint job and your petcock looks alot like his. He has a 81 kawasaki 440 b1. But I imagine they all look alike.
      1982 xj 1100
      "The Ape"
      http://youtu.be/AiQ8CqclHr4
      • Titbit21
        • Feb 2011
        • 76
        • Kent, Ohio
        I have pretty much come to the conclusion that I stuck having to order petcocks. Thanks for everyone's input
        '78E
          The left petcock is available new.
          http://www.powersportsplus.com/parts...ANK/parts.html
          Mike's XS has suitable replacements.
          http://www.mikesxs.net/product/20-0019.html
          Here's another option:
            • 3193
            If they have been working, except of course for the leak, you could buy the proper kits if you can ID them for sure. I have both sides for a standard here, but they would need the kits as well. Might also be a bike wrecker in your area that may have the correct ones.
