Carb re-assembly
  • Nubian
    • Apr 2011
    • 467
    • The Big East
    Carb re-assembly
    Besides the spring and washer, is there an o-ring on the idle mixture screw? And I just found out that the '79 Special and the '81 don't share the same gaskets Gonna be awhile before I ride. if my local shop does have the gaskets will have to order online. I guess meanwhile I can save time by building my synch tool
    BAMN!
    '81 XS1100H "Brutus"
    The tiny O ring goes below the washer on the 80-82 carbs.
    • Nubian
      • Apr 2011
      • 467
      • The Big East
      Between the washer and spring?
      BAMN!
        Yes, the 80-81 carbs with the recessed mix screw also have he needed o-rings. Order of placement on the ilde mix screw is spring,washer,0-ring. Washer keeps spring from tearing up o-ring during rotation of screw. Both washer and o-ring are NA from Yamaha, but the same pieces are available from Suzuki. Can give you the parts numbers if needed. I believe they are also available from georgesfix also. I got both locally as that was the easiest for me.
        • Nubian
          • Apr 2011
          • 467
          • The Big East
          That's what I thought I got some from my local napa auto parts but I can't get them seated maybe too thick. Afraid of putting too much pressure on it for the threads to grab.
          Would appreciate part #'s.
          BAMN!
            • 3193
              Harbor Freight sells a nitrile O ring kit ($4) that will have those tiny O rings for the mixture screws. It also has the ones for the needle seats.
              • mjpxs11sh
                • Jan 2011
                • 299
                • N/E, Illinois
                parts
                i bought mine for my 81SH when 1 of mine walked away. i got it from Mikes xs Part #48-5012. heres the link, go to the bottom of the page. it includes the mixture tower cover u probably wont use. he also has the mix screws. good luck
                http://www.mikesxs.net/products-37.html#products
                Max
                81 XS1100SH Black Beast Mutt
                Kerker 4/1
                stock carbs and air box.
                78 headlite, handle bars,
                1 set of ea-160/85mph guages,
                crash bars, cruise control
                Other 2 Wheelers
                78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
                94 CBR1000F jet kit,Two Bros pipe, K&N Filter
                  Along with the link Rasputin put up there, here are the part numbers from McMaster-Carr. The washer part# is 99040A316 and 0-ring# is 99040A316.
                    • 2104
                    Try some silicone grease lightly slathered on the assembly prior to installing.
                    HTH
                      Nope.........0-ring is the LAST thing that goes on up against the washer. Washer protects o-ring from damage from the spring........
                      • 81xsproject
                        • 3185
                        • Fortuna, CA
                        Just an FYI, I have the mixture o-rings/washer for $5 for all 4 carbs (MikesXS wants $4.50 ea.). PM me if interested.
                        '81 XS1100 SH
                        Sep. 12th 2015
                        RIP
