Following TopCatGrs' procedure for spring replacement and steel sanding. One of my brand new springs measures 1.645". The minimum service limit is 1.646" I only have inch calipers. This is handling the spring and calipers to give me the max measurement of that spring. Other handling gives me 1.640". The other new springs measure 1.665"-1.674". Just have the one that measures under. They are EBC springs. Should I use anyway? The old springs all measure in spec- should I use the best of that 6 in place of the single EBC?
My clutch slips when accelerating in second gear. I am using conventional diesel oil that IS NOT ENERGY CONSERVING. New cable adj to Haynes specs. My friction plates are all in spec-.117"-.120" service limit is .111"
Gonna go sand the steels now and will check back. Thanks!
You say your clutch slips, but that's rare for it to do that in the lower gears, usually they slip under higher loads of 4th or 5th gear.
But it's in there now, and until it starts slipping again, I probably won't be changing it...I still sweat every time I have to put that Star Plate back on!
