tonight was the night, we pulled the motor and onto the bench it went. ( it wasn't bad at all, with 2 of us it slid right over and out.) i pulled the bottom cover, clutch cover, and the other side cover. we examined everything, looked over what i printed from here and in the manual. here is my next batch of questions for those experienced in this operation.
where we are: you can see minor wear on the dogs and scoring on the inside of the primarydrive gear. it looks as if first is not getting pushed farther enough in.
how much slop should be inbetween the gears on this shaft?
is this one shaft removable without dorking with the clutch?
could there be another problem prevent 1st gear from engaging completely?
when we manually ****ed into first the gears seemed to mesh fine could i have a clutch problem after all?
i have some good photos and will post them as soon as i can them loaded
also on another note, when i removed the timing cover there is extensive corrosion on everything. is there something i can spray to help the situation?
