doesnt the frt of the driveshaft splines to the middle gear box need lubed? if theres no zirc fitting (as if that would help) it should be cleaned and repacked right? im pulling the final drive to lube it, and then it dawned on me,
what about everything forward of the final. ive never seen any posts on the subject and the manual doesnt specify much of anything about spline maintenance. is the factory installed lube good forever? its a little too cold to work on my bike right now, but im just waiting for some sun to show up for some garage heat.
Sometimes doing things the same way they used to do it is not the best answer.
