I have a small crack just above the cam chain tensioner. I brought the engine to a welder and he said that he would rather have me pull it apart or other components on the engine like the rings could get messed up.
I would have to pull it completely apart because the crack is on the bottom half of the engine just below were the head splits. Has anyone welded in this area before? Do you think there is a risk of damaging the cylinders/rings?
						 I....knew that.....I was.......just checking to see if you did.
