spline grease
    Originally posted by mjpxs11sh
    i still dont know how a pea sized amount of Moly 60 protects what took 1-2 Tbls of regular grease.
    Actually the good quality(high %) moly inpregnates the metal to create less friction. The Moly60 from your local Honda dealer IS the highest concetrate, as this IS what is factory reccomended for the splines when wheel is removed for a tire change on the ST's, Wings, and all other Honda 'shafties'. Interestingly enough tho, the final drive on these are reccomended to not be removed, as it changes factory alignment. The moly60 is used on the center-hub splines.
    • mjpxs11sh
      • Jan 2011
      • 299
      • N/E, Illinois
      grease
      thanx for all responses! anyone who can answer this simple question would b appreciated. after i "paint" the Moly 60 on the driveshaft splines with the final drive removed, should i also somewhat "pack" the female side with NLGI-2M grease? not sure if just using Moly 60 paste will lubricate everything since u dont use that much and the tube is only 3oz.
      Max
      81 XS1100SH Black Beast Mutt
      Kerker 4/1
      stock carbs and air box.
      78 headlite, handle bars,
      1 set of ea-160/85mph guages,
      crash bars, cruise control
      Other 2 Wheelers
      78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
      94 CBR1000F jet kit,Two Bros pipe, K&N Filter
        Just a little on the splines and go. No need to over-do or over-think it. Many are still going after 30+ years without ever opening that up and adding any grease to those splines, but I do recommend you do.
        Make sure to check that your U-joint moves free and easy. They don't ALL last a lifetime. This was my last one. The rusty dust you see is what's left of the little needle bearings in that cap.
        • clcorbin
          • Jan 2010
          • 495
          • Albuquerque, NM
          Ouch! How expensive was the new U-joint and how hard was it to find?
          -- Clint
            NA from Yammy...........A particular one from a forklift application is the same........sure someone will chime in with the information pertaining to that cross-reference...
              • 8800
              U-Joint here....
                It wasn't expensive or hard to find at all. I went and robbed one from one of my parts bikes. I took the caps off that one, put some new grease in there and slapped her back together.
                • clcorbin
                  • Jan 2010
                  • 495
                  • Albuquerque, NM
                  That is not nearly as bad as I would have thought.
                  -- Clint
                    Hmmmm..........wonder if that TUS-7 part designation would cross reference at my local bearing house supplier? Curiosity dictates that I check that out, and report my findings. These scoots are getting the use and miles with age, That IMO, is gonna become another more common failing point. Actually, amazing to me that it hasn't before now!
                      I just emailed that company that is listed for that U joint, asking if it had a grease zerk in it. He replied that it does have one on an end cap, in case anyone else was wondering. Makes more sense like that. That would be a tight fit in there to try to get on in the middle of the cross.
                        yup........otherwise would have to use a needle point like is used on the front CV joint in the older Broncos and such.
                        • CaptonZap
                          • Jun 2010
                          • 1748
                          • Denver
                          That begs the question of if there is enough room for the Zerk to clear the boot, and would it create a vibration issue at 100MPH? Grease it up, take out the Zerk, install pipe plug, never exceed the legal speed limit? CZ
                          • ddragon63
                            • Jan 2012
                            • 1101
                            • Ridgefield, WA
                            there's a reason we had solid non-external service u-joints on drag cars. It's your job to dismantle, inspect needles, grease, and/or replace after every season. Just because they say life time service doesn't mean your life time.....
                            If you think you should look @ it, it's probably time to take a look @ it....they don't grease themselves..
                            I took mine apart last week. 47k miles, I don't know if Dad ever serviced it. So I had to take a look.. Grease was old, needles were in good shape still. Cleaned, greased, reassembled. Better to know then to not...
                            Don
                            old:
                            1989 kawi ex500
                            1996 yzf-r6
                            1999 yzf-r1
                            2001 kawi zx-6r
                            2000 Ducati 748
                            2002 YZF-R1
                            2005 V-Star 1100 Classic
                              • 2083
                              I second that emotion.
                              Would it be possible to drill, tap and thread 2 or 4 zerks,placed for balance, in an OEM u-joint, and would they clear the boot?
                                Guess one could, but those bearing caps are hard high carbon steel.
