Priming oil pump
  • mack
    • 2411
    • Ontario, Canada
    Priming oil pump
    So I haven't seen this come up before, but knightops on another bike forum may have seized his 850 motor after a rebuild. Are these pumps self priming, or is there a way to get oil into the pump without splitting the cases and doing it manually?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    If the impellers in the pump have oil on them the pump will prime itself. I think there was another problem.
    If the bearings were lubed upon assembly they would have been fine until the pump picked up.
    XJOK2PLAY rode his XJ several miles with the oil pump laying in the oil pan when it fell off. These engines are hard to kill.
      I have not purposely opend the pump and cleaned every drop of oil out of it, but I have had the oil pump screen off and drained every drop that would drip from one before. Reinstalled it dry as that would get it, and never had an issue with the pump not priming and pressurizing.
      • ViperRon
        • Feb 2011
        • 1062
        • Woodstock, VA
        The clearances in these engines are pretty tight and typically even if the oil pump is completely dry there is a film of oil left on bearings. I would suggest that if someone is putting an oil pump that has been removed and reassembled that they manually check it before installation and that way when they reinstall it it will be primed I'd never depend on the dummy light to ensure lubrication got there. Any engine I reassemble and install all bearing and gear assemblies with assembly oil. I want to rotate the crank and pistons’ feeling bearings and gears for binds etc.
        I would imagine that if a person was worried that they may be able to pull loose the oil tube going from the head to the engine and make an adaptor to back pressure oil with a syringe. Possibly if in doubt you could remove the plugs and remove the same line and hit the starter till oil came out but what a mess.
        Rodan
        1980 G Silverbird
        1198 Overbore kit
        Grizzly 660 ACCT
        Barnett Clutch Springs
        R1 Clutch Fiber Plates
        122.5 Main Jets
        ACCT Mod
        Mac 4-2 Flare Tips
        Antivibe Bar ends
        Rear trunk add-on
          I don't think he even got it started did he? It stopped turning while cranking I thought.
            My experience is any non-submerged oil pump has to have some oil ran through it before assembling onto the motor. If it was disassembled/cleaned then installed dry (or with only a slight amount of oil in it), they won't self-prime.
              • 2104
              Is,would,could or should petroleum jelly still used for the priming of oil pumps?
                These pumps are submerged Steve.
                I've always just poured some oil into the pump and turned it by hand before installing it and never had a problem.
                  Originally posted by BA80
                  These pumps are submerged Steve..
                  I should have been clearer in what I meant... if the pump is submerged and will fill with oil via gravity (not the case with the XS pump), then you don't need to prime them. I'm with you, I always pour some oil through the pump to make sure it's primed...
                  • DAVINCI
                    • Jan 2011
                    • 1048
                    • Cedar Mountain, NC
                    The Golden Rule:
                    NOTHING inside the engine goes together dry
