carb adjustment
  • old_skool
    • Nov 2011
    • 554
    • Ohio
    carb adjustment
    is the carb adjustment a true fuel or is it actually an air adjustment, lean out rich in??
    81 XS1100H
    • 2104
    Fuel, lean in, rich out.
      Which part of the 'carb adjustment'? The idle mixture screws are changing the air/fuel mixture (in lean, out richer), but the sync is a 'balance' (making sure each carb is flowing the same amount of air).
        In answer to your question Oschool, if mixture screws are on intake/filter side of carbs, they are air screw adjustment. If the idle mix screws are on head/manifold side of carbs, they are fuel adjustment screws.
        • old_skool
          • Nov 2011
          • 554
          • Ohio
          Thanks, already did a preliminary sync, still sorting out the reason for the 2 center cylinders running so hot, thanks for the air/fuel adjustment info.
          81 XS1100H
            Steve, that is a confusing answer. The idle screws adjust the amount of fuel, everything else being the same.
