exhaust popping
  • old_skool
    • Nov 2011
    • 554
    • Ohio
    exhaust popping
    Just finished installing the rebuilt/cleaned carbs, and synced, cylinder 1&4 running a lot cooloer than 2&4...lean?? adjusting the carbs not making much difference, also, when warm, when starting-revs up to about 2500 then settles fairly quick to normal idle 1100-ish, pops through exhaust when letting off throtle after reving. has a slight exhaust leak where #2 header connects(needs new clamp) I guess, what possible causes for #2-3 running so hot and the popping and initial rev? stock jets, stock exhaust, pods.
    79SF
    81 XS1100H
    • 9980
    You need to re-sync. What type of sync tool are you using.
    • old_skool
      • Nov 2011
      • 554
      • Ohio
      just a manometer, clear line with red tranny fluid half up the board on each side, adjusted 1&2 then 3&4, then left to right with the center adjustment
      81 XS1100H
        • 9980
        Sounds like you did it correctly. Check it again it may be off again. I really don't trust that setup anyway.
        Try 1/4 out on the mixture screws on 2 &3 if that's ok.
        • old_skool
          • Nov 2011
          • 554
          • Ohio
          Never had any problem doing it that way, I noticed this bike has numerous exhaust leaks, will that contribute to the popping? Still not sure whats causing it to race at start then settle down, runs a little rough, maybe the exhaust is clogged, seems ok at the back, still have issuses with the mixture. And I need a couple clamps if any body has any, going to the middle two header pipes where they join just below the oil filter. Oh yeah, going to have to check compression too, PO washed the cylinders full of fuel also, when I got the bike, had a gallon of gas in there with the oil.
          81 XS1100H
            Exhaust leaks will contribute to the popping. get those fixed and go from there, even if you just temporarily plug them with something to see how it changes things.
            • trdriver71
              • 360
              • Edmonton Alberta
              did you adjust the mixture screw after you synced it? if you you will need to adjust those then resync again.
              '79 XS11SF
              • petejw
                • 2269
                • sydney australia
                leaky exhausts can cause the popping,
                but shouldnt cause it to run hot,
                did u check the float levels?
                are they set to stock, lean fuel levels can
                cause the engine to run hot.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                1981 xs1100 RH (aus) (5N5)
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • old_skool
                  • Nov 2011
                  • 554
                  • Ohio
                  Yeah, I plan on re-syncing till the cows come home, floats good, all set factory, not just a little hotter, a lot, I used a laser thermometer at the the bend of the exhaust header, 212-240 degrees on the outside pipes 480-541 in the inner.
                  Adjusting the mixture wasn't making much difference unless drastic turns in or out.
                  81 XS1100H
                  • petejw
                    • 2269
                    • sydney australia
                    u havent accidently broken any tips
                    of the mixture screws, that could also
                    cause u the problem, especially if turning
                    them doesnt make any difference.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                    • old_skool
                      • Nov 2011
                      • 554
                      • Ohio
                      I'll double check, but they all looked good originally when I installed them.
                      81 XS1100H
                      • ViperRon
                        • Feb 2011
                        • 1062
                        • Woodstock, VA
                        You may want to check to ensure the Carb boots are tight as a vacume leak can create problems with carb adjustments making cylinders run lean and adjustments seem to change.
                        Rodan
                        1980 G Silverbird
                        1198 Overbore kit
                        Grizzly 660 ACCT
                        Barnett Clutch Springs
                        R1 Clutch Fiber Plates
                        122.5 Main Jets
                        ACCT Mod
                        Mac 4-2 Flare Tips
                        Antivibe Bar ends
                        Rear trunk add-on
                        • old_skool
                          • Nov 2011
                          • 554
                          • Ohio
                          I think it's a combination of 2 things, I did discover the carb boots aren't tight enough, and the exhaust was horrible, left side muffler was completely broke loose around the the pipe at the crossover junction, had holes in the bottom near the rear on the same side, center connecting headers loose below the oil filter area. Re-welded the muffler, patched the bottom holes, picking up some new clamps tomorrow, muffler had a little more surface rust that wouldn't clean up, so high temp black paint performed a temporary miracle...lol
                          Will take care of the clamps on the exhaust and carb boots tomorrow and go from there. Not sure how much all of that affected the 2 center cylinders running way hotter than the outer ones, after all is re-hooked up, will re-sync and attempt to adjust the mixture....fingers crossed. Hopefully I don't have to pull the carbs again, everything was spotless....except....forgot to pull the emulsion tubes.
                          81 XS1100H
