octy/petcock debate?
  • Filter
  • #16
    do i have to filter the tube at all?
    1979 xs special, just finished the top end rebuild and then i still have lots of work.
    progress thus far...
    http://s1268.photobucket.com/albums/...t=IMAG0202.jpg
    "If it runs bad, it's usually the carbs. If the tires go flat, I suspect the carbs. If the wind blows the bike over, the carbs were probably to blame. If my wife yells at me about something, I tell her to talk to the carbs" -Incubus
    • #17
      You should not have to filter the crancase breather hose since the flow is most always out due to normal blowby but it is better that you do. The two lines that are the carb bowl vents ought to be filtered since they normally reside in the filtered part of the airbox. Small fuel filters work well here.
      Here is a view of my old setup before I switched carbs.
      And here is how I have my breather filtered.
      Mike Giroir
      79 XS-1100 Special
      • #18
        thanks a million :-D
