Shock covers
  • Titbit21
    • Feb 2011
    • 76
    • Kent, Ohio
    Shock covers
    I don't know why, but I want some. I don't think they do much but I think they give a good look. So I have been looking for some and was wondering if anybody out there knows the size that I should be looking for. I found these but Im not sure if they would fit. http://http://www.ebay.com/itm/Motor...item3371166ea3
    '78E
    Uh, the link doesn't work....
    As far as 'shock covers', you have to find some with a big enough inside diameter to clear the springs. The other thing to keep in mind is most of the aftermarket covers don't have 'dampers' in them and can be 'rattlers' sometimes.
      • 8052
      Those gaiters were made for a 31 mm fork. Yours is 37 mm. The answer to your question is, no, they won't fit.
      Steve,
      He's looking at front fork gaiters. I won't help with the link because there's no use looking at it.
      • Titbit21
        • Feb 2011
        • 76
        • Kent, Ohio
        Ah fork gaiters. Helps if I give the right term. Sorry for the confusion. Thanks for the answer Marty. Ill keep my eyes open for some 37's.
        '78E
        • CRXSi90
          • Jun 2004
          • 400
          • Madison, Wisconsin
          Here is the link for those who are interested:
          http://www.ebay.com/itm/Motorcycle-F...item3371166ea3
          If you can't find anything you like which is intended for motorcycles, another option might be the shock boots which are intended for automotive/truck shocks.
          http://www.amazon.com/Rancho-RS1952-.../dp/B000CPCCFY
          '81 XS11H Venturer - holed up in storage while life happened since 07/08/04
          '81 Kawasaki KE175 enduro - 63 mph of smokey fun, now with collector plates!
