Auto Cam Chain Tensioner Cross Reference
  • Auto Cam Chain Tensioner Cross Reference
    Heh Fellas,
    I've got the idea by now that the auto CTT is a great idea to do. Now my question is.... other than the Venture what other models of bikes CTT can you install on a XS11. I may decide to do the swap. Just wanna know what bikes to start shopping the part off of
    Thanks guys,
    Don
    Don
    old:
    1989 kawi ex500
    1996 yzf-r6
    1999 yzf-r1
    2001 kawi zx-6r
    2000 Ducati 748
    2002 YZF-R1
    2005 V-Star 1100 Classic
    The V-max uses the same tensioner as the Venture, the Vision ones will work with a bit of elongation down/left in the upper mounting hole, and it was just posted that a Raptor tensioner will also fit.... lots of choices!
      Well thats good news cuz you can get a Raptor auto CCT off flea-bay for 10 bucks free shipping! Sold! Winner? ME!
      Don
      old:
      1989 kawi ex500
      1996 yzf-r6
      1999 yzf-r1
      2001 kawi zx-6r
      2000 Ducati 748
      2002 YZF-R1
        Someone should write up a tech tip for the swap and include the known bikes they can be pulled from with whatever modifications are necessary.
        Website/Blog
          If someone would like to do a check on the year ranges on the ACCTs mentioned and post it, a tech tip will be forthcoming....hint, hint...
            Tell you what Steve.... When I get my Raptor CTT here I will do my swap. With picture, and will research what years they are the same for the Raptors. As these seem to be readily available on Ebay for CHEAP I think if they work in an 1100 motor they are the wave of the future for this Mod. I would think that Yamaha probably uses this CTT on alot more than the Raptor's for a modern world part. so even new, they should be readily available. Anyways it would be my pleasure to research it and do a setup by step for the tech tip section with HD pictures. including cross references for modern bikes for the CTT
            Don
            old:
            1989 kawi ex500
            1996 yzf-r6
            1999 yzf-r1
            2001 kawi zx-6r
            2000 Ducati 748
            2002 YZF-R1
              Check one thing on that ACCT when you get it; see how the spring tension compares to the stock one. There's a considerable difference between the V-max/Venture spring and the Vision unit (with the V-max spring being much stiffer compared to OEM/Vision), good info to have to make a decision on...
                Will do... I could see where too much spring pressure could be a problem. No need to wear anything out faster than normal. If there feels to be a difference I will see if I can fit it in my valve spring pressure tester and compare them scientifically
                Don
                old:
                1989 kawi ex500
                1996 yzf-r6
                1999 yzf-r1
                2001 kawi zx-6r
                2000 Ducati 748
                2002 YZF-R1
                  I'm still a little stunned the Raptor CCT worked out so well. I seriously just searched Ebay for Yamaha tensioners and chose one that looked right. The Yamaha engineers probably figured "why change it?" and just copy pasted the tensioner in a CAD program. Who knows where else they implemented this same design.
                  As far as the spring stiffness, I'm no expert, but I'd say it's pretty close to the original. Just going by feel really.
                  I might take mine off and put some RTV on it instead of using the paper gasket. Only reason I'm using the paper is because I recently did a rebuild and I bought one of those Athena gasket sets. (which are a pretty good deal btw)
                  80 XS11 "Bellatrix"- MAC 4-1, ZRX1200 carbs, Dynatek Coils, Raptor CCT
                    Gasket? LOL ultra black RTV for me thanks
                    I'll check the spring out. But my theory is if its a little stiffer that's OK as long as its not too much more pressure. I'm sure the factory spring from 1979 had more pressure when it was brand new.
                    Don
                    old:
                    1989 kawi ex500
                    1996 yzf-r6
                    1999 yzf-r1
                    2001 kawi zx-6r
                    2000 Ducati 748
                    2002 YZF-R1
                      According to boats.net all these fit. YMMV
                      1983 XVZ12TDK CAMSHAFT - CHAIN
                      1984 VENTURE - XVZ1200L CAMSHAFT CHAIN
                      1984 VENTURE - XVZ1200LC CAMSHAFT CHAIN
                      1984 VENTURE ROYALE - XVZ1200DL CAMSHAFT CHAIN
                      1984 VENTURE ROYALE - XVZ1200DLC CAMSHAFT CHAIN
                      1984 XVZ12DKC2 CAMSHAFT - CHAIN
                      1984 XVZ12DL CAMSHAFT - CHAIN
                      1984 XVZ12KC2 CAMSHAFT - CHAIN
                      1984 XVZ12L CAMSHAFT - CHAIN
                      1985 V MAX 1200 - VMX12N CAMSHAFT - CHAIN
                      1985 V MAX 1200 - VMX12NC CAMSHAFT - CHAIN
                      1985 V-MAX - VMX1200N CAMSHAFT CHAIN
                      1985 V-MAX - VMX1200NC CAMSHAFT CHAIN
                      1985 VENTURE ROYALE - XVZ1200DN CAMSHAFT CHAIN
                      1985 XVZ12DN CAMSHAFT - CHAIN
                      1986 V-MAX - VMX1200S CAMSHAFT CHAIN
                      1986 V-MAX - VMX1200SC CAMSHAFT CHAIN
                      1986 V-MAX 1200 - VMX12S CAMSHAFT - CHAIN
                      1986 V-MAX 1200 - VMX12SC CAMSHAFT - CHAIN
                      1986 VENTURE ROYALE - XVZ1300DS CAMSHAFT - CHAIN
                      1986 VENTURE ROYALE - XVZ1300DSC CAMSHAFT - CHAIN
                      1986 XVZ13DS CAMSHAFT - CHAIN
                      1986 XVZ13DSC CAMSHAFT - CHAIN
                      1987 VENTURE - XVZ1300T CAMSHAFT CHAIN
                      1987 VENTURE - XVZ1300TC CAMSHAFT CHAIN
                      1987 VENTURE ROYALE - XVZ1300DT CAMSHAFT CHAIN
                      1987 VENTURE ROYALE - XVZ1300DTC CAMSHAFT CHAIN
                      1987 XVZ13DT CAMSHAFT - CHAIN
                      1987 XVZ13DTC (CA ED.) CAMSHAFT - CHAIN
                      1987 XVZ13T CAMSHAFT - CHAIN
                      1987 XVZ13TC (CA ED.) CAMSHAFT - CHAIN
                      1988 V-MAX - VMX1200U CAMSHAFT CHAIN (CALIFORNIA MODEL ONLY)
                      1988 V-MAX - VMX1200U CAMSHAFT CHAIN (NON-CALIFORNIA MODEL)
                      1988 V-MAX - VMX1200UC CAMSHAFT CHAIN (CALIFORNIA MODEL ONLY)
                      1988 V-MAX - VMX1200UC CAMSHAFT CHAIN (NON-CALIFORNIA MODEL)
                      1988 V-MAX 1200 - VMX12U CAMSHAFT - CHAIN (CALIFORNIA MODEL ONLY)
                      1988 V-MAX 1200 - VMX12U CAMSHAFT - CHAIN (NON-CALIFORNIA MODEL)
                      1988 V-MAX 1200 - VMX12UC CAMSHAFT - CHAIN (CALIFORNIA MODEL ONLY)
                      1988 V-MAX 1200 - VMX12UC CAMSHAFT - CHAIN (NON-CALIFORNIA MODEL)
                      1988 VENTURE - XVZ1300U CAMSHAFT CHAIN
                      1988 VENTURE - XVZ1300UC CAMSHAFT CHAIN
                      1988 VENTURE ROYAL - XVZ13DU CAMSHAFT CHAIN
                      1988 VENTURE ROYAL - XVZ13DUC CAMSHAFT CHAIN
                      1988 VENTURE ROYALE - XVZ1300DU CAMSHAFT CHAIN
                      1988 VENTURE ROYALE - XVZ1300DUC CAMSHAFT CHAIN
                      1988 XVZ1300D CAMSHAFT CHAIN
                      1988 XVZ13U CAMSHAFT-CHAIN
                      1988 XVZ13UC (CA ED.) CAMSHAFT-CHAIN
                      1989 V-MAX - VMX1200W CAMSHAFT CHAIN CALIFORNIA MODEL ONLY
                      1989 V-MAX - VMX1200W CAMSHAFT CHAIN NON CALIFORNIA MODEL
                      1989 V-MAX - VMX1200WC CAMSHAFT CHAIN CALIFORNIA MODEL ONLY
                      1989 V-MAX - VMX1200WC CAMSHAFT CHAIN NON CALIFORNIA MODEL
                      1989 V-MAX 1200 - VMX12W CAMSHAFT CHAIN CALIFORNIA MODEL ONLY
                      1989 V-MAX 1200 - VMX12W CAMSHAFT CHAIN NON CALIFORNIA MODEL
                      1989 V-MAX 1200 - VMX12WC CAMSHAFT CHAIN CALIFORNIA MODEL ONLY
                      1989 V-MAX 1200 - VMX12WC CAMSHAFT CHAIN NON CALIFORNIA MODEL
                      1989 VENTURE ROYALE - XVZ1300DW CAMSHAFT CHAIN
                      1989 VENTURE ROYALE - XVZ1300DWC CAMSHAFT CHAIN
                      1989 XVZ12DWC CAMSHAFT - CHAIN
                      1990 V-MAX - VMX1200A CAMSHAFT CHAIN
                      1990 V-MAX - VMX1200AC CAMSHAFT CHAIN
                      1990 V-MAX 1200 - VMX12A CAMSHAFT CHAIN
                      1990 V-MAX 1200 - VMX12AC CAMSHAFT CHAIN
                      1990 VENTURE ROYALE - XVZ1300DA CAMSHAFT CHAIN
                      1990 VENTURE ROYALE - XVZ1300DAC CAMSHAFT CHAIN
                      1990 XVZ13DA CAMSHAFT - CHAIN
                      1990 XVZ13DAC (CA ED.) CAMSHAFT - CHAIN
                      1991 V-MAX - VMX1200B CAMSHAFT CHAIN
                      1991 V-MAX - VMX1200BC CAMSHAFT CHAIN
                      1991 V-MAX 1200 - VMX12B CAMSHAFT CHAIN
                      1991 V-MAX 1200 - VMX12BC CAMSHAFT CHAIN
                      1991 VENTURE ROYALE - XVZ1300DB CAMSHAFT CHAIN
                      1991 VENTURE ROYALE - XVZ1300DBC CAMSHAFT CHAIN
                      1991 XVZ13DB CAMSHAFT - CHAIN
                      1991 XVZ13DBC CAMSHAFT - CHAIN
                      1992 V-MAX - VMX1200D CAMSHAFT CHAIN
                      1992 V-MAX - VMX1200DC CAMSHAFT CHAIN
                      1992 V-MAX 1200 - VMX12D CAMSHAFT CHAIN
                      1992 V-MAX 1200 - VMX12DC CAMSHAFT CHAIN
                      1992 VENTURE ROYALE - XVZ1300DD CAMSHAFT CHAIN
                      1992 VENTURE ROYALE - XVZ1300DDC CAMSHAFT CHAIN
                      1992 XVZ13DD CAMSHAFT-CHAIN
                      1992 XVZ13DDC CAMSHAFT-CHAIN
                      1993 V-MAX - VMX1200E CAMSHAFT CHAIN
                      1993 V-MAX - VMX1200EC CAMSHAFT CHAIN
                      1993 V-MAX 1200 - VMX12E CAMSHAFT CHAIN
                      1993 V-MAX 1200 - VMX12EC CAMSHAFT CHAIN
                      1993 VENTURE ROYALE - XVZ1300DE CAMSHAFT CHAIN
                      1993 VENTURE ROYALE - XVZ1300DEC CAMSHAFT CHAIN
                      1993 XVZ13DE CAMSHAFT-CHAIN
                      1993 XVZ13DEC (CA ED.) CAMSHAFT-CHAIN
                      1994 V-MAX - VMX1200F CAMSHAFT CHAIN
                      1994 V-MAX - VMX1200FC CAMSHAFT CHAIN
                      1994 V-MAX 1200 - VMX12F CAMSHAFT CHAIN
                      1994 V-MAX 1200 - VMX12FC CAMSHAFT CHAIN
                      1995 V-MAX - VMX1200G CAMSHAFT CHAIN
                      1995 V-MAX - VMX1200GC CAMSHAFT CHAIN
                      1995 V-MAX 1200 - VMX12G CAMSHAFT CHAIN
                      1995 V-MAX 1200 - VMX12GC CAMSHAFT CHAIN
                      1996 ROYAL STAR - XVZ1300AH CAMSHAFT CHAIN
                      1996 ROYAL STAR - XVZ1300AHC CAMSHAFT CHAIN
                      1996 ROYAL STAR TOUR CLASSIC - XVZ1300ATH CAMSHAFT CHAIN
                      1996 ROYAL STAR TOUR CLASSIC - XVZ1300ATHC CAMSHAFT CHAIN
                      1996 ROYAL STAR XVZ13ATH_ATHC ROYAL STAR TOUR CLASSIC - XVZ13AH CAMSHAFT CHAIN
                      1996 ROYAL STAR XVZ13ATH_ATHC ROYAL STAR TOUR CLASSIC - XVZ13AHC CAMSHAFT CHAIN
                      1996 ROYAL STAR XVZ13ATH_ATHC ROYAL STAR TOUR CLASSIC - XVZ13ATH CAMSHAFT CHAIN
                      1996 ROYAL STAR XVZ13ATH_ATHC ROYAL STAR TOUR CLASSIC - XVZ13ATHC CAMSHAFT CHAIN
                      1996 V-MAX - VMX1200H CAMSHAFT CHAIN
                      1996 V-MAX - VMX1200HC CAMSHAFT CHAIN
                      1996 V-MAX 1200 - VMX12H CAMSHAFT CHAIN
                      1996 V-MAX 1200 - VMX12HC CAMSHAFT CHAIN
                      1996 XVZ13THC CAMSHAFT CHAIN
                      1997 ROYAL STAR - XVZ1300AJ CAMSHAFT CHAIN
                      1997 ROYAL STAR - XVZ1300AJC CAMSHAFT CHAIN
                      1997 ROYAL STAR TOUR CLASSIC - XVZ1300ATJ CAMSHAFT CHAIN
                      1997 ROYAL STAR TOUR CLASSIC - XVZ1300ATJC CAMSHAFT CHAIN
                      1997 ROYAL STAR TOUR DELUXE - XVZ1300LTJ CAMSHAFT CHAIN
                      1997 ROYAL STAR TOUR DELUXE - XVZ1300LTJC CAMSHAFT CHAIN
                      1997 V-MAX 1200 - VMX12J CAMSHAFT CHAIN
                      1997 V-MAX 1200 - VMX12JC CAMSHAFT CHAIN
                      1997 XVZ13AJ CAMSHAFT CHAIN
                      1997 XVZ13AJC CAMSHAFT CHAIN
                      1997 XVZ13ATJ CAMSHAFT CHAIN
                      1997 XVZ13ATJC CAMSHAFT CHAIN
                      1997 XVZ13LTJ CAMSHAFT CHAIN
                      1997 XVZ13LTJC (CA ED.) CAMSHAFT CHAIN
                      1998 ROYAL STAR STANDARD - XVZ1300AK CAMSHAFT CHAIN
                      1998 ROYAL STAR STANDARD - XVZ1300AKC CAMSHAFT CHAIN
                      1998 ROYAL STAR TOUR CLASSIC - XVZ1300ATK CAMSHAFT CHAIN
                      1998 ROYAL STAR TOUR CLASSIC - XVZ1300ATKC CAMSHAFT CHAIN
                      1998 ROYAL STAR TOUR DELUXE - XVZ1300LTK CAMSHAFT CHAIN
                      1998 ROYAL STAR TOUR DELUXE - XVZ1300LTKC CAMSHAFT CHAIN
                      1998 V-MAX - VMX1200K CAMSHAFT CHAIN
                      1998 V-MAX - VMX1200KC CAMSHAFT CHAIN
                      1998 V-MAX 1200 - VMX12K CAMSHAFT CHAIN
                      1998 V-MAX 1200 - VMX12KC CAMSHAFT CHAIN
                      1998 XV13LTK CAMSHAFT CHAIN
                      1998 XV13LTKC CAMSHAFT CHAIN
                      1998 XVZ13AK CAMSHAFT CHAIN
                      1998 XVZ13AKC CAMSHAFT CHAIN
                      1998 XVZ13ATK CAMSHAFT CHAIN
                      1998 XVZ13ATKC CAMSHAFT CHAIN
                      1998 XVZ13LTK CAMSHAFT CHAIN
                      1998 XVZ13LTKC CAMSHAFT CHAIN
                      1998 XVZ13TLKC CAMSHAFT CHAIN
                      1999 ROYAL STAR BOULEVARD - XVZ1300AL CAMSHAFT CHAIN
                      1999 ROYAL STAR BOULEVARD - XVZ1300ALC CAMSHAFT CHAIN
                      1999 ROYAL STAR BOULEVARD - XVZ13AL CAMSHAFT CHAIN
                      1999 ROYAL STAR BOULEVARD - XVZ13ALC CAMSHAFT CHAIN
                      1999 ROYAL STAR TOUR CLASSIC (CA ED.) - XVZ13ATLC CAMSHAFT CHAIN
                      1999 ROYAL STAR TOUR CLASSIC - XVZ1300ATL CAMSHAFT CHAIN
                      1999 ROYAL STAR TOUR CLASSIC - XVZ1300ATLC CAMSHAFT CHAIN
                      1999 ROYAL STAR TOUR CLASSIC - XVZ13ATL CAMSHAFT CHAIN
                      1999 ROYAL STAR TOUR DELUXE (CA ED.) - XVZ13LTLC CAMSHAFT CHAIN
                      1999 ROYAL STAR TOUR DELUXE - XVZ1300LTL CAMSHAFT CHAIN
                      1999 ROYAL STAR TOUR DELUXE - XVZ1300LTLC CAMSHAFT CHAIN
                      1999 ROYAL STAR TOUR DELUXE - XVZ13LTL CAMSHAFT CHAIN
                      1999 ROYAL STAR VENTURE - XVZ1300TFL CAMSHAFT CHAIN
                      1999 ROYAL STAR VENTURE - XVZ1300TFLC CAMSHAFT CHAIN
                      1999 ROYAL STAR VENTURE - XVZ13TFL CAMSHAFT CHAIN
                      1999 ROYAL STAR VENTURE - XVZ13TFLC CAMSHAFT CHAIN
                      1999 V-MAX - VMX1200L CAMSHAFT CHAIN
                      1999 V-MAX - VMX1200LC CAMSHAFT CHAIN
                      1999 V-MAX 1200 - VMX12L CAMSHAFT CHAIN
                      1999 V-MAX 1200 - VMX12LC CAMSHAFT CHAIN
                      2000 ROYAL STAR (Yamaha Black) (CA Ed.) - XVZ13AMC CAMSHAFT CHAIN
                      2000 ROYAL STAR (Yamaha Black) - XVZ13AM CAMSHAFT CHAIN
                      2000 ROYAL STAR BOULEVARD - XVZ1300AM CAMSHAFT CHAIN
                      2000 ROYAL STAR BOULEVARD - XVZ1300AMC CAMSHAFT CHAIN
                      2000 ROYAL STAR TOUR CLASSIC (CA Ed.) - XVZ13ATMC CAMSHAFT CHAIN
                      2000 ROYAL STAR TOUR CLASSIC - XVZ1300ATM CAMSHAFT CHAIN
                      2000 ROYAL STAR TOUR CLASSIC - XVZ1300ATMC CAMSHAFT CHAIN
                      2000 ROYAL STAR TOUR CLASSIC - XVZ13ATM CAMSHAFT CHAIN
                      2000 ROYAL STAR TOUR DELUXE - XVZ1300LTM CAMSHAFT CHAIN
                      2000 ROYAL STAR TOUR DELUXE - XVZ1300LTMC CAMSHAFT CHAIN
                      2000 ROYAL STAR VENTURE (CA ED.) - XVZ13TFMC CAMSHAFT CHAIN
                      2000 ROYAL STAR VENTURE - XVZ1300TFM CAMSHAFT CHAIN
                      2000 ROYAL STAR VENTURE - XVZ1300TFMC CAMSHAFT CHAIN
                      2000 ROYAL STAR VENTURE - XVZ13TFM CAMSHAFT CHAIN
                      2000 ROYAL STAR VENTURE MM - XVZ1300TFSM CAMSHAFT CHAIN
                      2000 ROYAL STAR VENTURE MM - XVZ1300TFSMC CAMSHAFT CHAIN
                      2000 V-MAX (Yamaha Black) (CA Ed.) - VMX12MC CAMSHAFT CHAIN
                      2000 V-MAX (Yamaha Black) - VMX12M CAMSHAFT CHAIN
                      2000 V-MAX - VMX1200M CAMSHAFT CHAIN
                      2000 V-MAX - VMX1200MC CAMSHAFT CHAIN
                      2000 VENTURE MM LIMITED EDITION (CA Ed.) - XVZ13TFSMC CAMSHAFT CHAIN
                      2000 VENTURE MM LIMITED EDITION - XVZ13TFSM CAMSHAFT CHAIN
                      2000 XVZ13LTM (Yamaha Black) CAMSHAFT CHAIN
                      2000 XVZ13LTMC (Yamaha Black) (CA Ed.) CAMSHAFT CHAIN
                      2001 ROYAL STAR BOULEVARD - XVZ1300AN CAMSHAFT CHAIN
                      2001 ROYAL STAR BOULEVARD - XVZ1300ANC CAMSHAFT CHAIN
                      2001 ROYAL STAR TOUR DELUXE (YAMAHA BLACK) (CA ED.) - XVZ13LTNC CAMSHAFT CHAIN
                      2001 ROYAL STAR TOUR DELUXE (YAMAHA BLACK) - XVZ13LTN CAMSHAFT CHAIN
                      2001 ROYAL STAR TOUR DELUXE - XVZ1300LTN CAMSHAFT CHAIN
                      2001 ROYAL STAR TOUR DELUXE - XVZ1300LTNC CAMSHAFT CHAIN
                      2001 V-MAX - VMX1200N CAMSHAFT CHAIN
                      2001 V-MAX - VMX1200NC CAMSHAFT CHAIN
                      2001 VENTURE (CA Ed.) - XVZ13TFNC CAMSHAFT CHAIN
                      2001 VENTURE - XVZ1300TFN CAMSHAFT CHAIN
                      2001 VENTURE - XVZ1300TFNC CAMSHAFT CHAIN
                      2001 VENTURE - XVZ13TFN CAMSHAFT CHAIN
                      2002 ROYAL STAR MIDNIGHT VENTURE (Yamaha Black) (CA Ed.) - XVZ13TFSPC CAMSHAFT CHAIN
                      2002 ROYAL STAR MIDNIGHT VENTURE (Yamaha Black) - XVZ13TFSP CAMSHAFT CHAIN
                      2002 ROYAL STAR MIDNIGHT VENTURE - XVZ1300TFSP CAMSHAFT CHAIN
                      2002 ROYAL STAR MIDNIGHT VENTURE - XVZ1300TFSPC CAMSHAFT CHAIN
                      2002 ROYAL STAR VENTURE (CA Ed.) - XVZ13TFPC CAMSHAFT CHAIN
                      2002 ROYAL STAR VENTURE - XVZ1300TFP CAMSHAFT CHAIN
                      2002 ROYAL STAR VENTURE - XVZ1300TFPC CAMSHAFT CHAIN
                      2002 ROYAL STAR VENTURE - XVZ13TFP CAMSHAFT CHAIN
                      2002 V-MAX (New Silver Dust) - VMX12P CAMSHAFT CHAIN
                      2002 V-MAX (New Silver Dust) - VMX12PC CAMSHAFT CHAIN
                      2002 V-MAX - VMX1200P CAMSHAFT CHAIN
                      2002 V-MAX - VMX1200PC CAMSHAFT CHAIN
                      2003 ROYAL STAR MIDNIGHT VENTURE (Onyx) (CA Ed.) - XVZ1300TFSRC CAMSHAFT CHAIN
                      2003 ROYAL STAR MIDNIGHT VENTURE (Onyx) - XVZ1300TFSR CAMSHAFT CHAIN
                      2003 ROYAL STAR MIDNIGHT VENTURE - XVZ1300TFS CAMSHAFT CHAIN
                      2003 ROYAL STAR VENTURE (CA Ed.) - XVZ1300TFRC CAMSHAFT CHAIN
                      2003 ROYAL STAR VENTURE - XVZ1300TFR CAMSHAFT CHAIN
                      2003 V-MAX (Matte Black) (CA Ed.) - VMX12RC CAMSHAFT CHAIN
                      2003 V-MAX (Matte Black) - VMX12R CAMSHAFT CHAIN
                      2003 V-MAX - VMX1200R CAMSHAFT CHAIN
                      2003 V-MAX - VMX1200RC CAMSHAFT CHAIN
                      2004 ROYAL STAR MIDNIGHT VENTURE - XVZ13TFMS CAMSHAFT CHAIN
                      2004 ROYAL STAR MIDNIGHT VENTURE - XVZ13TFMSC CAMSHAFT CHAIN
                      2004 ROYAL STAR VENTURE - XVZ13TFS CAMSHAFT CHAIN
                      2004 ROYAL STAR VENTURE - XVZ13TFSC CAMSHAFT CHAIN
                      2004 V-MAX - VMX1200S CAMSHAFT - CHAIN
                      2004 V-MAX - VMX1200SC CAMSHAFT - CHAIN
                      2004 V-MAX - VMX12S1 CAMSHAFT CHAIN
                      2004 V-MAX - VMX12SC1 CAMSHAFT CHAIN
                      2005 ROYAL STAR MIDNIGHT VENTURE - XVZ13TFMT CAMSHAFT CHAIN
                      2005 ROYAL STAR MIDNIGHT VENTURE - XVZ13TFMTC CAMSHAFT CHAIN
                      2005 ROYAL STAR TOUR DELUXE - XVZ13CTT CAMSHAFT CHAIN
                      2005 ROYAL STAR TOUR DELUXE - XVZ13CTTC CAMSHAFT CHAIN
                      2005 ROYAL STAR VENTURE - XVZ13TFT CAMSHAFT CHAIN
                      2005 ROYAL STAR VENTURE - XVZ13TFTC CAMSHAFT CHAIN
                      2005 V-MAX 1200 - VMX12T CAMSHAFT CHAIN
                      2005 V-MAX 1200 - VMX12TC CAMSHAFT CHAIN
                      2006 ROYAL STAR MIDNIGHT TOUR DELUXE - XVZ13CTMV CAMSHAFT CHAIN
                      2006 ROYAL STAR MIDNIGHT TOUR DELUXE - XVZ13CTMVC CAMSHAFT CHAIN
                      2006 ROYAL STAR MIDNIGHT VENTURE - XVZ13TFMV CAMSHAFT CHAIN
                      2006 ROYAL STAR MIDNIGHT VENTURE - XVZ13TFMVC CAMSHAFT CHAIN
                      2006 ROYAL STAR TOUR DELUXE - XVZ13CTV CAMSHAFT CHAIN
                      2006 ROYAL STAR TOUR DELUXE CA - XVZ13CTVC CAMSHAFT CHAIN
                      2006 ROYAL STAR VENTURE - XVZ13TFV CAMSHAFT CHAIN
                      2006 ROYAL STAR VENTURE CA - XVZ13TFVC CAMSHAFT CHAIN
                      2006 V-MAX 1200 - VMX12V CAMSHAFT CHAIN
                      2006 V-MAX 1200 - VMX12VC CAMSHAFT CHAIN
                      2007 ROYAL STAR MIDNIGHT TOUR DELUXE - XVZ13CTMW CAMSHAFT CHAIN
                      2007 ROYAL STAR MIDNIGHT TOUR DELUXE CA - XVZ13CTMWC CAMSHAFT CHAIN
                      2007 ROYAL STAR MIDNIGHT VENTURE - XVZ13TFMW CAMSHAFT CHAIN
                      2007 ROYAL STAR MIDNIGHT VENTURE CA - XVZ13TFMWC CAMSHAFT CHAIN
                      2007 ROYAL STAR TOUR DELUXE - XVZ13CTW CAMSHAFT CHAIN
                      2007 ROYAL STAR TOUR DELUXE CA - XVZ13CTWC CAMSHAFT CHAIN
                      2007 ROYAL STAR VENTURE - XVZ13TFW CAMSHAFT CHAIN
                      2007 ROYAL STAR VENTURE CA - XVZ13TFWC CAMSHAFT CHAIN
                      2007 V-MAX - VMX12W1 CAMSHAFT CHAIN
                      2007 V-MAX CA - VMX12W1C CAMSHAFT CHAIN
                      2008 ROYAL STAR TOUR DELUXE (DEEP PURPLISH BLUE METALLIC L - BLACK METALLIC X) (CA ED.) - XVZ13CTXC CAMSHAFT CHAIN
                      2008 ROYAL STAR TOUR DELUXE (DEEP PURPLISH BLUE METALLIC L - BLACK METALLIC X) - XVZ13CTX CAMSHAFT CHAIN
                      2008 ROYAL STAR TOUR DELUXE S (DARK BLUISH GRAY METALLIC 8 - SILVER 3) (CA ED.) - XVZ13CTSXC CAMSHAFT CHAIN
                      2008 ROYAL STAR TOUR DELUXE S (DARK BLUISH GRAY METALLIC 8 - SILVER 3) - XVZ13CTSX CAMSHAFT CHAIN
                      2008 ROYAL STAR VENTURE (VERY DARK RED METALLIC 2 - BLACK METALLIC X) (CA ED.) - XVZ13TFXC CAMSHAFT CHAIN
                      2008 ROYAL STAR VENTURE (VERY DARK RED METALLIC 2 - BLACK METALLIC X) - XVZ13TFX CAMSHAFT CHAIN
                      2008 ROYAL STAR VENTURE - XVZ13TFXCR CAMSHAFT CHAIN
                      2008 ROYAL STAR VENTURE - XVZ13TFXR CAMSHAFT CHAIN
                      2008 ROYAL STAR VENTURE S (DARK BLUISH GRAY METALLIC 8) (CA ED.) - XVZ13TFSXC CAMSHAFT CHAIN
                      2008 ROYAL STAR VENTURE S (DARK BLUISH GRAY METALLIC 8) - XVZ13TFSX CAMSHAFT CHAIN
                      2008 ROYAL STARTOUR DELUXE - XVZ13CTXCL CAMSHAFT CHAIN
                      2008 ROYAL STARTOUR DELUXE - XVZ13CTXL CAMSHAFT CHAIN
                      2009 ROYAL STAR TOUR DELUXE (DARK RED METALLIC K) (CA ED.) - XVZ13CTYCR CAMSHAFT CHAIN
                      2009 ROYAL STAR TOUR DELUXE (DARK RED METALLIC K) - XVZ13CTYR CAMSHAFT CHAIN
                      2009 ROYAL STAR TOUR DELUXE S (DARK BLUISH GRAY METALLIC 8) (CA ED.) - XVZ13CTSYC CAMSHAFT CHAIN
                      2009 ROYAL STAR TOUR DELUXE S (DARK BLUISH GRAY METALLIC 8) - XVZ13CTSY CAMSHAFT CHAIN
                      2009 ROYAL STAR VENTURE (DEEP RED METALLIC K - BLACK METALLIC X) (CA ED.) - XVZ13TFYCR CAMSHAFT CHAIN
                      2009 ROYAL STAR VENTURE (DEEP RED METALLIC K - BLACK METALLIC X) - XVZ13TFYR CAMSHAFT CHAIN
                      2009 ROYAL STAR VENTURE S (LIGHT YELLOWISH GRAY METALLIC 9) (CA ED.) - XVZ13TFSYC CAMSHAFT CHAIN
                      2009 ROYAL STAR VENTURE S (LIGHT YELLOWISH GRAY METALLIC 9) - XVZ13TFSY CAMSHAFT CHAIN
                      2010 ROYAL STAR TOUR DELUXE S - XVZ13CTSZ CAMSHAFT & CHAIN
                      2010 ROYAL STAR TOUR DELUXE S - XVZ13CTSZC CAMSHAFT & CHAIN
                      2010 ROYAL STAR VENTURE S - XVZ13TFSZ CAMSHAFT & CHAIN
                      2010 ROYAL STAR VENTURE S - XVZ13TFSZC CAMSHAFT & CHAIN
                      2011 ROYAL STAR VENTURE S - XVZ13TFSA CAMSHAFT CHAIN
                      2011 ROYAL STAR VENTURE S - XVZ13TFSAC CAMSHAFT CHAIN
                      2-79 XS1100 SF
                      2-78 XS1100 E Best bike Ever
                        Oh is that all?
                        • #13
                          Nope that is all that the site shows for the 84 venture. If you were to include the vision and the raptor etc I imagine we would have wide list to choose from. I only posted this as am example of what "may" be out there.
                          2-79 XS1100 SF
                          • #14
                            Thanks Rasputin... that's a hell of a list!
                            Don
                            old:
                            1989 kawi ex500
                            1996 yzf-r6
                            1999 yzf-r1
                            2001 kawi zx-6r
                            2000 Ducati 748
                            2002 YZF-R1
                            • #15
                              Not many to choose from then. Could be a problem finding one.....
