Fork uppers
  • Fork uppers
    Anyone know if the fork uppers are interchangeable between specials and standards?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    No they won't, different lengths and different type of slider bushing. All Special 79-81 will be the same.
      Thanx
      Think I may have done a lot of work for nothing, Andreas only has standard forks left and I can't get the c clips out of the lowers from the rust and crap that has distorted them. I may be able to cut them out but the washer is toast as well and they're not aqvailable.I see a set of forks on flea bay but who knows if they're any better than what I have now. Not a good day!
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
        Check with Greg (BA80) he might have some. You can also get NEW fork uppers from forking by frank as well, so the issue is going to be finding the c-clips and washers which I'm sure someone on here probably has some in decent shape (I don't, I only have standard parts aside from the non-titled special frame I have). The other option on those washers might be to find out if there is a replacement that can be used from something else, since that part is NLA it might be worth either finding a replacement or finding someone who has the machining equipment to run off a few of them. It would seem that there might be another bike somewhere that would have one close enough to do the job?
          forks
          don't know if I can help but I have complete set of standard forks,calipers,fender,master cylinder if need be. the forks did work but needs new seals. Pm me if you want them and we can discuss a very decent price for all or part of it.
            I've got one extra set of special forks but I think I should hang on to them................just in case.
            Keep watching fleabay, they show up cheap every now and then
              JAT, ask Andreas, he might have some good ones.
                I have a really nice set of lower tubes for the 81LH here and no use for them. I have 2 uppers but I changed them out for a set from Andreas as mine have some rust pitting on the area where there is no fork travel. Either or are yours for shipping, but as I have seen pics of your build I am sure you would not want my uppers.
                2-79 XS1100 SF
                2-78 XS1100 E Best bike Ever
                  Actually, Mack. They will interchange.
                  Here's a couple of links to past discussions -
                  http://www.xs11.com/forum/showthread.php?t=20283
                  http://www.xs11.com/forum/showthread.php?t=24996&page=2
                    In for a penny
                    in for the pound. I have one good spare upper here already that will work. I've gone this far now, sort of toying with the idea of taking one of the originals to the same guy that did my gold and have it stripped, repaired and re-chromed. I still have about six weeks before I can open the garage door to tune it anyway. I want to see if I can save my lowers first before I do anything else. Thanx everyone, I'll get back to you.
                    mack
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    613-398-6186
                      .. I have one good spare upper here already that will work. I've gone this far now, sort of toying with the idea of taking one of the originals to the same guy that did my gold and have it stripped, repaired and re-chromed...
                      Mack, I've got a set of Special forks that aren't bad; one only has a few very small pits right below the lower tree, the other one a bit worse. No pitting in the seal area. Pics if you're interested, send me a PM.
                      Don't have a 'ordinary' plating shop re-do yours; that's a special type of plating, and a 'normal' polished finish won't hold up. Just ask the Harley guys that buy the polished tubes... it peels off after a bit of wear, then they're trash...
                        I think I'm
                        going to be ok Steve. I measured the travel and the bad area's on my spare forks should miss the seals. I put the uppers in my lowers today and the bushings are pretty good, no play at all through the entire stroke. I have a smile once again. That box of carb parts you sent me in the summer sure came in handy. The bodies with intact posts have be sent to members who needed them and the rest of the parts I used to rebuild three sets of 80-81's and three sets of 78-79's. a lot of good stuff there. Thanx again.
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
