I picked up my bike last weekend and as part of changing all the fluids, I flushed and bleed the brakes. Everything went smoothly, and I had solid brakes when I was done. Fast forward to this past weekend, and while washing the bike Saturday morning, I noticed both the front and rear wheels had some resistance from the calipers. I tried bleeding the system again, but it just made the issue worse.
So doing some searching, it would appear my spooge holes are clogged and that's most likely the reason for my calipers not releasing. My whole brake system looks pretty shoddy really. The line covering is dry rotted, the MC's were dirty and empty when I picked the bike up, and the pads are all pretty much shot.
So how far down the rabbit hole do I go? At the very least, I'm getting new pads and brake lines all around and clean the spooge holes. Should I also just go ahead and grab the master cylinder rebuild kits? And if I go that far, should I just go ahead and rebuild the calipers as well? The bike does have 86k on it and I'm unsure if it's ever been done before.
What would you do?
What would you do?
At 86K miles, a complete rebuild is probably needed. One other thing you may want to budget for is caliper pistons; you won't know until you get the calipers apart, but if those are pitted on the outside circumference, new pistons are probably in order. Luckily, you can now get reproduction pistons made from stainless steel; not too many years ago these were unobtainium.....
