May wanna check the length as the XS grips or replacements ARE shorter than for newer scoots.
If they look like what you want then go for it. Every ride I have has thicker grips be they Kuryakin's or Yamaha brand. Makes the clutch harder to adjust but the ride is way more comfortable. The ones I buy are regularily 80 bucks or so and I am happy to pay it. Do what you want and will like!
2-79 XS1100 SF 2-78 XS1100 E Best bike Ever 80 XS 1100 SG Big bore kit but not fully running yet.
As any replacement grips are usually longer I use that opportunity to use spacers or washers to act as bar end weights that also change the vibrations that you end up with. It means that I do not get the usual hand goes to sleep on a long ride. YMMV
