Top Five Upgrades
  • Joab
    replied
    How essential do you folks feel the Auto Tensioner is?
    Leave a comment:
  • CraigMel13
    replied
    ew, ew, ew, ew, pick me I have an upgrade for you guys.....trade it for a Suzuki!
    Just kidding....My personal first upgrade involved a sawzall and welder. Check my build out in the XS11/XJ11 Discussion forum.
    Leave a comment:
  • ddragon63
    replied
    Yep rear on a special is 16"
    Leave a comment:
    replied
    Here's the original thread with the wheel differences.... http://www.xs11.com/forum/showthread...ghlight=wheels
    The 'tube' wheels only came on the '78 and early '79 standards, all others were tubeless and so marked with a stamped 'suitable for tubeless' note. Not to say that these couldn't end up newer bikes, so if there's any doubt, check....
    And here's how to convert the rear to tubeless...http://www.xs11.com/forum/showthread...ghlight=wheels
    Leave a comment:
    replied
    Those are the 16" wheels......
    Leave a comment:
  • ddragon63
    replied
    1979 xs1100sf factory wheels read suitable for tubeless.
    Leave a comment:
    replied
    Hey Greg,
    Yes, folks have converted their tubed front rims to be able to use tubeless tires, but due to the bead difference, "we" can not condone this practice. It could lead to the tire coming loose from the rim during an inexpected quick deflation scenario which could lead to a MORE catastrophic handling situation that just the flat tire alone...! HENCE THE BEAD LOCKS designed into the OEM tubed rims! With the tire still well seated against the rim bead, you can still retain "some" handling ability while you're trying to slow down, but if the tire comes off the rim/bead, you are pretty much SOL and will be sliding down the road on your side fairly quickly!
    Well "I" was talking about the 17" rear rim. Although this may be a problem in theory I have never heard of it happening.
    The 19" front rim is pretty standard on ALL XSs, 650 on up through all years it would definitly not be a problem finding a front tubless wheel. However, the 17" is a little more difficult.
    Leave a comment:
    replied
    Originally posted by BA80
    Come to think about it Russ has been running a tubless tire on his standard rim for quite a while. All he did was seal up the rim lock hole the same way the tubless valve stem is sealed. With rubber washers.
    Hey Greg,
    Leave a comment:
  • ddragon63
    replied
    1: gas in the tank
    2: oil in the case
    3: air in the tires
    4: sunshine
    5: open road in front of me
    the rest is just a bonus
    Leave a comment:
  • Pat Kelly
    replied
    5 super-models in bikinis (optional) to wash it.
    Leave a comment:
    replied
    Originally posted by cywelchjr
    79 standards you have to check, but the ONLY difference between the tubeless rear and the tube rear is the rim lock hole(s). Other than that they are the same casting, this has been confirmed by crazy steve comparing both side by side, the front tube and tubeless however are actually different with a different profile so you really need to find the correct rim for the front, unless it's one of the later 79's that came with tubeless rims since not all 79 standards came with tube type rims.
    Leave a comment:
    replied
    The Special has a 16" rim though Cy and his F will be a 17".
    80 and 81 Standards have a 17" tubless rim. If you look on ebay at 850 rims, which will fit, you can get up to a 19" I believe.
    Leave a comment:
    replied
    He's looking for tubless Marty.
    Leave a comment:
    replied
    How about putting a 130/80-17 tire on it? That will get it closer to the Special.
    Leave a comment:
    replied
    All specials unless they have had older standard rims put on them have tubeless rims on them already as they came with tubeless rims from the factory from the beginning.
    Leave a comment:
