metalic rattle
  • petejw
    • 2269
    • sydney australia
    metalic rattle
    my engine has developed a metalic rattle
    sounds like a nut is bouncing around the engine,
    it can be heard at idle, it quiet downs a bit under throttle
    and returns when the revs are constant.
    the rattle isnt coming from the cam chain or top end and
    sounds like its on the left hand side of the engine somewhere,
    ive got a stethoscope but cant pin point exactly where its coming
    from, was wondering if any one else has experience something
    similar or has any ideas what may have come loose, before i
    start tearing down the engine.
    thanx in advance.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    Hey Pete,
    I don't recall what engine work you have done on your bike, ie. dremel gear fix or such? I think I remember folks reporting that kind of noise when their countershaft bolt worked loose and was grinding against the inner side of the clutch bucket!? But I've also heard folks describe primary chain slap in a similar manner!? Good luck finding it, hope it isn't too serious, let us know what you find!
      • 9980
      That's what my original SG engine started doing. I tore the whole ignition out hoping it was something simple. No luck.
      I still haven't torn into that engine but I assume it's a main bearing.
        • 9980
        Hey Pete,
        I think I remember folks reporting that kind of noise when their countershaft bolt worked loose and was grinding against the inner side of the clutch bucket!? T.C.
        Other side of the engine TC.
        • petejw
          • 2269
          • sydney australia
          hey TC,
          ive done a top end rebuild a cpl of thousand miles ago
          and have done the 2nd gear fix a cpl of years ago,
          when i did the top end i removed the oil pan and found
          a broken piece of bakerlite sitting in the bottom,
          which came from the primary chain guide, up until now
          there was no noise, so its quite possible that it is the chain
          rattling, thanx for the reply.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • petejw
            • 2269
            • sydney australia
            hey greg,
            doesnt sound like a bearing, sounds like its coming
            more from the middle of the engine.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
              • 9980
              Hmmm... I thought you said left. Did you mean left center?
              ahhhhh.......just read your previous post. Sounds like a slider fell apart. How's your chain tension?
              • petejw
                • 2269
                • sydney australia
                im having trouble telling exactly where its coming from,
                its not the top end, i can hear it more on the left side
                than the right, the sounds travelling around the gear case/
                timing covers, but could also be coming from the engine
                under the carbs.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                  • 9980
                  Drop the oil pan and see what's in there. More bakerlite and you'll know what's up.
                  Metal flakes and you'll HATE what's up.
                    • 9980
                    Unfortunately this is what I found when I pulled my oil pan......
                      That's never a good thing to find....
                      The only upside is they're still theoretically rebuildable... once you add 'extra' vent holes, they're toast...
                      • SFerinTEXAS
                        • Jun 2006
                        • 876
                        May not be this but I heard a buzz/rattle on my SF a few weeks before the factory exhaust split under the heat shield. Drove me nuts till it became obvious.
                        79SF
                        XJ11
                        78E
                        • petejw
                          • 2269
                          • sydney australia
                          greg, unfortunately ive been there before with a
                          rolled con rod bearing, never a pretty site.
                          ill drop the oil pan first and see what i find.
                          its definately a metalic rattle, like a nut rolling around
                          in a steel can, hasnt affected the way the engine runs,
                          tho i havent taken it out for a ride since ive heard the noise.
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
                          • rpgoerlich
                            • Dec 2007
                            • 643
                            • Katy, Tx
                            Developed a rattle at intermittent speeds last week. Found it Sunday. Turned out to be the front lower rivet in the RH exhaust, I believe to hold the baffle in place. Now to replace it...
                            Richard
                              • 9980
                              As long as the bearing didn't take the case with it.
                              Hopefully it's as simple as that Pete. Doesn't hurt to pull the pan though especially because you found what you did before.
                              The pan is an easy check.
