Question on transmission repair
  • #16
    Yes; 10-4, turbox79 >.......would appreciate that.
    Did you do shifting fork modification, on the Suzuki, as well as
    the XS11 ?
    JCarltonRiggs
    • #17
      yes thats how we figured it out on the xs because the suzuki guys have been doing it for years
      copy and paste
      http://www.imagestation.com/members/turbox79
      • #18
        Dang! > ......the more I talk to you > the more I NEED to talk to you ! (turbox79) .
        .......Now, I got a good one for you :> ? What is Bob Jones (Merriamcycles) doing for taller gearing, to get the top speed(s) mph, that I've heard, bantied about.......with his "re-manufactured" XS's ??
        ........?? either in the transmission, or somewhere between the transmission and rear wheel............??.........or all the above ??.......
        JCarltonRiggs
        • #19
          I dont know about trans gears but on my xs with a 17 inch wheel my top speed is faster on the street but at the track I go thrugh the traps in 4th gear and with a 16 inch wheel I go through in 5th so thats how I gear it.
          17=salt flats
          16=1/4 mile
          I wish I could get a 15 inch wheel and better test
          copy and paste
          • #20
            .......for a good long time, that's the reason, I've wanted to put
            the 17' rear wheel, from my organ donater Standard > on my
            Special. The 17' tire on the rim, is about 2 inches more in circumference, than the 16' tire mounted on its rim. All kinds of threads and postings on here >"? how to get less RPM at same MPH ? "..........; you're the first one to post -- one of the ways, actually in use.
            I've always, really wanted to do it, cuz I figured it would handle a tad better. Would be a larger "tire patch" contact on the road.
            Hadn't read yer last post yet; it just now came on, while I was typing this.
            JCarltonRiggs
            • #21
              It doesnt matter on my bike on handling because i run a tiny front wheel and no suspension so straight is all it goes.straight and fast
              copy and paste
              • #22
                Hey there Turbo,
                I editted your message a few messages above, then I realized that you had that picture link in your "Signature" . Are you wanting to display that picture everytime you post a message, to be added to your signature, or were you trying to provide the "LINK" so folks could go to it if they wanted to see it?
                Have you thought about shrinking it down to make it an AVATAR image? Didn't mean to but in, just trying to help, "if" it's wanted!!
                To make it a working link you need to remove the extra ".orig.jpg" at the end of the file name after the first ".jpg" !
                And to Carlton,
                I have the same bike, and am able to run a Dunlop 140/90x16, the raised letters rubbed just a little against the left driveshaft / swingarm, but otherwise fits okay and rides nicely. I don't know how much more of a lengthwise contact patch you would get with the 17" vs. the 16", but the above does give a nicer "wider" contact area!
                • #23
                  Is yours still rubbin' ? I've got that same size tire in a Kenda. About 5000 miles on it. It never did rub, but there wuz very little
                  daylight between tire and driveshaft housing. Might be about
                  the clearance of a thin sheet of paper. Never did touch..........
                  JCarltonRiggs
                  • #24
                    The raised white letters were just slightly beyond/above the edge of the actual sidewall, so after the 'crown' wore off, there wasn't anything else to rub, the sidewalls don't contact at all! It was amazing how much better the handling was after I put that tire on, was running the mountains in Ga. and Tenn. during the last fall rally, made a big difference!! Still scraped mufflers and footpegs though!!
                    • #25
                      Yep, I can remember how happy I was with the improvement in
                      handling when I did put that new tire on; but, at the same time, I
                      did put on a new tire on the front, though. I wuz really ecstatic, when about a year later, I put the fork brace on............
                      JCarltonRiggs
                      • #26
                        thanks TopCatGr58 I dont care ether way will work I dont have patience to mess with it while im at work so thanks again.
                        about the 140 90 16 i have bee thinking of trying it will the 140 80 16 fit or is it to low profile and what about 17
                        copy and paste
                        • #27
                          Hey there Turbo,
                          I just went to the Dunlop Motorcycle Tire page, they list only a
                          MT90/16=130/90x16 Raised White Letter at 5.20" wide.
                          MU90/16=140/90x16 RWL is 5.57" wide.
                          They don't list a 140/80, they show a 160/80x16 at 6.10" wide!!
                          I forgot to mention, mine is a special, and I think folks have stated that there is a little more room due to the extra spacer vs. Standards!?
                          I was trying to find info/description on clarifying what the 140/90 info means, I thought it was the total diameter in mm of the tread, by the height of the sidewall? My sidewall if you include the bead would be 90mm, but my total tread surface measurement across the curve of the tire is 160mm, however if I could draw a straight line across from one edge of the tread bead to the other, it might be actually only 140mm wide?
                          So, I would think that a tire that is 140mm tread width with only 80mm sidewall would be a bit shorter, but not necessarily much wider, but it would vary from brand to brand, and tire style !?
                          PS, I can't edit your profile for your signature, you'll have to do that yourself, but I think that picture, cropped and shrunk would make a decent AVATAR!!!
                          • #28
                            I talked with my dad and he said that he dont remember having spacer issues ether and that he agrees that you should back cut your trans and he said that MRE I think did the work Im going to find out later if they still are doing it
                            my brother has a 140 80 17 it z rated so it should last about five minuts. its on his suzuki and its a avon, he said I could try it so Ill let you guys know about that when I get to it
                            140 is the width
                            second number 90 or 80 is the highth
                            and third is the rim
                            copy and paste
                            • #29
                              here is the link for the place that built the trans for my xs call them and find out a price it would be worth it especally if your trying to build a hi horse power motor
                              http://www.murdochracing.com/index.htm
                              copy and paste
                              • #30
                                Tire numeral explanation:
                                http://www.tirerack.com/tires/tirete...formation.html
                                It uses a cage tire, but the explanation is OK.
                                Marty in NW PA
                                This IS my happy face.
