want some feed back on my project
  • Nightengale
    replied
    Originally posted by Nightengale
    thinking about using this instead of a key, what do you guys think, thanks to tomB for this idea.http://www.focalprice.com/HA643X/YU0...l?Currency=GBP
    scratch that i have decided to keep it simple low tech, and use a hidden switch instead of the key less thing to go wrong and i can always find the switch, but i know i would lose that remote.
    Leave a comment:
  • Nightengale
    replied
    keyless
    Leave a comment:
  • Nightengale
    replied
    plates
    Originally posted by GLoweVA
    Just wondering, are you putting gauges on it?
    Speedo/Tach?
    I've got a special (round one) speedo (and braket) lying around (the tach is shot)
    I'll snap a pic of it and post it up here and if you want it, you can have it.
    Maybe you can modify the bracket to hold just the speedo and not worry about the tach.
    I guess you're not too worried about the VA state inspection.
    You can always go with the antique plates and skip the inspection.
    thats what i am gonna do is antique plates, i thought that would add to the look of the bike too.
    Leave a comment:
  • Nightengale
    replied
    Here's a pic of the speedo I got. The bracket should bolt right on to the tree.
    thanks but i just ordered one a small one from mikes xs. the same goes for you if you want any of the parts that i took off the bike just let me know since you just live a short ride away.
    Leave a comment:
  • GLoweVA
    replied
    Leave a comment:
  • GLoweVA
    replied
    Speedo/Tach?
    Leave a comment:
  • Nightengale
    replied
    pics
    here is a pic of my tank before i started working on it, not bad but needs some work
    after stripping to bare metal then bondo, primer, and first coat of paint, with alot of sanding in between.
    wiring before
    now with everything in the faux oil tank
    Leave a comment:
  • Nightengale
    replied
    little more done
    got a little more done on the wiring done today just a few little things. i spent most of the day working on my tank. I stripped it down to bare metal. I used a spray on stripper, but it took forever since the tank had so many layers. it did do a good job tho. once i got the tank stripped i could really see how many little dings there were on the tank, so i got out the bondo and did a light skim over the entire tank to fill in all the little imperfections. worked nicely. started with 80 grit and worked my way to 350 grit and it got the tank really smooth, real sleek looking with the badges filled and all the dents gone. I have it primed and ready to wet sand to get it ready for paint. camera died but i will post a pic later to show how the tank turned out. I think it turned out great i cant wait to get some paint on it.
    Leave a comment:
  • Nightengale
    replied
    wiring
    worked on the wiring for a while today, my buddy that was gonna help wasnt able to make it, i started by myself. i got a little bit done, but spent most of the time looking at the wiring diagram and looking at the harness to make sure i know what was what and making sure i know what every thing was. I did get most of the electrical put into the faux oil tank, but have to make a few adjustment here and there to make sure everything workes out just right. i will do some more work tomorrow and take some pics. wish me luck, i think i have bit off more than i can chew with the wiring, but i if i take my time and do one thing at a time i belive i will be ok. it will take longer than i had planed, but at least by doing it a little at a time i can make sure everything is done right. i am so tempted to just rush through it and get this thing on the road, but i know that if i do something will be missed, and i dont want any problems later down the road.
    Leave a comment:
  • Nightengale
    replied
    i hear ya
    Originally posted by tv5150
    Seriously, I hope it turns out killer and it's all you hope for.
    Nothing more gratifying than that git 'er dun feeling that
    leaves a grin a mile wide that's hard to wipe off your mug...
    so far it has been an awsome. this is my first build and wont be my last. everyone i know is tired of hearing about it. i get really excited about every little thing that i have done to this bike. the bike is slowly evolving in fornt of my eyes and i am loving every minuite of it. the closer if get to finishing it the more excited i get. thanks again. one thing that i love about this site is that everyone on here sees and understands how much time and work i am putting into this build, even though not everyone likes what i have done to the bike, they can all appreciate the hard work involved in what i am doing and the fact that i am seeing it through to the end, and putting one of these great bikes on the road instead of rusting away in someones back yard. i know that alot of people here have seen people start these kind of projects, then either lose intrest of find out that it is alot of work and just give up thus ending the life of a great bike, but i hope i have showed everyone that i will see this through to the end (which is right around the corner).
    Leave a comment:
  • tv5150
    replied
    i do thank you for that piece of advice, and i will watch out for that. this bike is not going to be used on long rides (the longest might be 3 hours, with a ton of stops). it will be used to scoot around town on and maybe back and forth to work (20 min. away), but i do appreciate the concearn.
    Leave a comment:
  • Nightengale
    replied
    thanks
    Yeah, I understand, but when you get the final seat on it, then follow the above directions to see if it is cushy enough
    Leave a comment:
  • tv5150
    replied
    the seat thats on the bike now was just something that i made just to get the mounting brackets and springs attached. the one that i am going to use has closed cell foam padding and covered in leather. I wouldnt think of riding with that seat on it its not even comfortable just sitting on it. I have seen some guys with the seats with no padding on it, but there is no way i could do it.
    Leave a comment:
  • Nightengale
    replied
    not my seat
    Here's a novel idea to see if your seat has enough spring action...
    After riding it hard for several days and miles, when you stop to take a whiz, always use a white paper towel to whiz thru and if you don't see red, it's cushey enough, but if you do see red, you might wanna re-think the seat set-up
    Just enjoy being young, cause when you get old and brittle, you'll end-up paying for them younger days...don't ask how I know
    The build looks great BTW...wish I were young enough to enjoy something like that again.
    Leave a comment:
  • tv5150
    replied
    Seat Testing
    Leave a comment:
