Carb Rebuild Gas pouring out
  • Spootinay
    • Jul 2011
    • 62
    • NE FL
    okay, I've set all the floats to spec. That is top of the floats to where the gasket sits, not the gasket itself right? I've taken the bowels off and check for leaks from the needles. none found. needles and housings are clean and shiny.
    and the little bastard is still leaking. it comes out as fast as it goes in.
    can i adjust all the floats to different levels all out of spec if i use the clear tube thingy to make sure i have the correct fuel level in each bowel?
      • 8641
      Measure from the gasket surface with the gasket removed to the highest point on the float. Remember, when filling the bowls with gas for the first time, tap them with a screwdriver handle to prevent the floats from sticking. Only use the tube method to set the float level if you have an 81 or later setup with the spigots on the bottom of the bowls.
      โ˜ฎ
        I'm starting to wonder is you have mixed parts in your carbs, or if they're even the '78-79 type...
        What do the float valve seats look like? Are they threaded and screw into the carb housing? If they do, they do have the red fiber gaskets under them, right? Don't screw in, but are held in with small 'Y' shaped brackets? Then you have the '80-81 type carbs and the needles are wrong. Plus these are sealed with o-rings, and the o-rings are famous for shrinking and leaking. Replace with new valves, the problem should go away...
        A couple of pics of the carbs would really help.
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          • Fort Myers, Florida
          #34
          Your pain!
          1st, I feel your pain Went through the same thing Did you also adjust the max float opend tang? If not, the floats can jam open. Next, how are you testing, is the test tank alot higher then the stock tank would be on the bike (mine leaked badly due to to much fuel pressure from that, on testing) Check to make sure the floats dont hit anything like the gaskets also. Many folks have no bleed down at all at shut off, I am not so lucky, but the bike runs great and I just shut of the petcocks a few sec before the motor to be sure / safe Good luck with your bike, I know the carbs can be a PITA sometimes
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
            • 9980
            Here's the pic he put up earlier steve. Definitly 78-79 bodies.
            Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid.โ€
            โ€• Albert Einstein
              #36
              http://i1188.photobucket.com/albums/...y/photo1-4.jpg
              Yep, they are '78-79; thanks Greg. It simply might be just worn-out valves/seats, sometimes they can look OK to the naked eye but not be good...
                #37
                I have not read back through the entire thread, so forgive me if this was covered. Years ago when I first rebuilt my first set of XS11 carbs, I did the bench test, no leaks. I then did the off the bike on a rack test, no leaks. And then time, after time, after time, after time, the bloody blinking carbs would leak when mounted on the bike. A fellow local XSsive always described his bike as looking like it had been rolled down a hill and set on fire, since I live on a hill, I was threatening to make mine match his!!! I was so tired of leaking bloody carbs!!
                Well, after the umpteenth time of removing, and cleaning the carbs, float valves, seats (all of which were brand spanking new of course, and the 81 viton type), I finally saw the little black specks in the valve seats, then I noticed them in the fuel Ts. I finally figured out that the automotive style rubber lines I was using, kind with two cores, soft inner rubber, harder outer rubber, were chaffing off little pieces of rubber every time I put them on the babred Ts and tightened the little hose clamps I was using with them. I went to the local hardware store and bought the yellow plastic lawn mower fuel line. Put that on instead, and never had another issue with the carbs on that one leaking!
                May not be your problem, but it sure had me for a while!
                  • 9980
                  I hate to repeat what's already been suggested but.......are you CERTAIN your hooking the fuel inlet hoses to the INLET Ts and NOT the VENT Ts.
                  โ€• Albert Einstein
                  • Spootinay
                    • Jul 2011
                    • 62
                    • NE FL
                    #39
                    Lol yeah I'm hooking the fuel lines to the fuel tees.
                    the needle seats screw in and have red gaskets.
                    testing with carb off the bike gas level mimicking the tank.
                    floats are free to move up and down.
                    gas comes out the bottom right hole:
                    Ill set the max open tab and tap with a screw driver and get back to ya
                      #40
                      At this point, I'd try bench testing these again but with a twist. Pull the bowls, turn the carbs upside down so the valves are closed, then put fuel to them. If the valves are leaking, you'll see where. You shouldn't get much if any fuel past the needles if they're good...
                      • DAVINCI
                        • Jan 2011
                        • 1048
                        • Cedar Mountain, NC
                        #41
                        Just to clarify one more time what Greg wrote...the fuel tees are the LOWER tees. The vent tees are the UPPER tees. Got that?
                        • runningbear
                          • Apr 2010
                          • 18
                          • Mt Pleasant, Michigan
                          #42
                          will a wireharness off an 80 midnight special work on an 80 special
                            #43
                            Yes, except for trim they're identical...
                            • mack
                              • 2411
                              • Ontario, Canada
                              #44
                              Circles
                              Can you be more specific so we don't go in circles here. Which carb is leaking, or are they all leaking. You describe the flow from the bottom right hole. I assume the 4 o clock hole as the carbs would sit in the bike. Your drop tabs have been set and when you roll the carbs front to back the floats move freely and don't hang up on the bottom of the post. As the carbs would sit on the bike, you have the fuel lines hooked to the bottom T's. Am I right so far?
                              mack
                              79 XS 1100 SF Special
                              HERMES
                              original owner
                              81 XS 1100 LH MNS
                              SPICA
                              78 XS 11E
                              IOTA
                              https://youtu.be/wB5Jfbp6SUc
                              https://youtu.be/RaI3WYHSuWA
                              Frankford, Ont, Canada
                              613-398-6186
                              • mack
                                • 2411
                                • Ontario, Canada
                                #45
                                Interesting
                                That 4 0 clock hole is the starter jet and connects to the emulsion tube tower through a diagonal port located imediately behind the float posts. Just learned that myself last week. The level of your fuel would have to be much too high for it to come out that hole if you lines are hooked to the correct t's
                                mack
                                HERMES
                                original owner
                                81 XS 1100 LH MNS
                                SPICA
                                78 XS 11E
                                IOTA
                                613-398-6186
