has anyone replaced their 1157's with the LED bulbs? If so some feed back. obviously if they're true LED they will use a fraction of the power of the standard 1157 bulbs. But has anyone put them thru the test? lil leery about the Chinese ones you can get off Flea bay for $1.04 a pair free shipping.
LED replacement bulbs
Don
old:
1989 kawi ex500
1996 yzf-r6
1999 yzf-r1
2001 kawi zx-6r
2000 Ducati 748
2002 YZF-R1
2005 V-Star 1100 ClassicTags: None
You would most likely have to change out the flasher unit. You would have to switch it to an electronic flasher to counter the lower wattage. Problem with this is that you will loose the auto cancel option.1980 Yamaha XS1100SG
1984 Honda VF700F Interceptor
1967 Yamaha YL2C
Hey Don,
In the FORUM tech tips...not necessarily the drop down menu tips, under the MODS, ELECTRICAL, you'll find a few about LED bulbs for turn signals and also for tail lights. They are a few years old, but there's a LINK to the site that carries the very bright LEDS in bulbs and other styles that can be used in the tail lights...don't just look in the car/auto section, but also in the truck, and even boat/misc.
Some folks have used a prebuilt BULB with a cluster of LEDS on the end of the socket, but have reported that they don't look as bright as the OEM bulb.
There are other styles of LED arrays available, like a detached grid array of LEDS connected to an 1157 socket so you can position the array in the tail light pointing straight back no matter which direction the actual socket is pointing! They also have newer designs with LEDS mounted around the sides of the bulb/socket as well as the ends, so you get light sideways to provide better side visibility as well as posterior! YMMV!
Amazing what you can find in the tech tips!!
T.C.T. C. Gresham
Originally posted by Azoroth View PostYou would most likely have to change out the flasher unit. You would have to switch it to an electronic flasher to counter the lower wattage. Problem with this is that you will loose the auto cancel option.
Not too concerned about auto cancel.
Thanks for the heads up. I've bought the chepo led grid style before for a bike... not impressed. When the instructions call for a hot glue gun to hold the grid into the socket I just say no.Was just wondering if anyones tryed the bulb style ones. sounds like the search continues
Don
old:
1989 kawi ex500
1996 yzf-r6
1999 yzf-r1
2001 kawi zx-6r
2000 Ducati 748
2002 YZF-R1
Originally posted by ddragon63 View PostI never though about the flasher thing... I know when I upgraded the signals on my R1 that they came with a diode to slow the blinker down if desired.Nathan
If you're looking for a US seller for the LED's, SuperBrightLEDs.com is located about 15 minutes from where I sit right now. I've been to their facility, and they are very good to work with. Lots of cool toys too!1980 XS850SG - Sold
Originally posted by natemoen View PostThat diode is actually a load equalizer that actually ups the effective current draw to make your flasher see the same larger load of incandescent bulbs. If you are looking for lower current draw this is not the way to go cause it does not lower the actual draw any.
Originally posted by CatatonicBug View PostIf you're looking for a US seller for the LED's, SuperBrightLEDs.com is located about 15 minutes from where I sit right now. I've been to their facility, and they are very good to work with. Lots of cool toys too!Don
old:
1989 kawi ex500
1996 yzf-r6
1999 yzf-r1
2001 kawi zx-6r
2000 Ducati 748
2002 YZF-R1
I bought the dash lights for my gauges from superbrightled. There are decent price and worked great. I did have to return one that was defective. But that happens. I kinda woah that I could get the fuel and headlight warning lights to work with led. I would have to get a load equalizer wich kind of defeats the purpose.1980 Yamaha XS1100SG
1967 Yamaha YL2C
Hi Don,
I'm sure the low load on the flasher thing can be fixed with the right flasher unit so long as you are prepared to give up on the self-cancelling feature.
What would concern me is that I read that the LED powered 1157 lamps are directional, they shoot the light straight back; while (on my bike at least) the dual 1157s go in sideways.Fred Hill, S'toon
Originally posted by fredintoon View PostHi Don,
What would concern me is that I read that the LED powered 1157 lamps are directional, they shoot the light straight back; while (on my bike at least) the dual 1157s go in sideways.1980 Yamaha XS1100SG
1967 Yamaha YL2C
Originally posted by Azoroth View Postsuperbrightleds.com has 1157 bulbs that are 90 degree angle.Don
old:
1989 kawi ex500
1996 yzf-r6
1999 yzf-r1
2001 kawi zx-6r
2000 Ducati 748
2002 YZF-R1
What would concern me is that I read that the LED powered 1157 lamps are directional, they shoot the light straight back; while (on my bike at least) the dual 1157s go in sideways.Cy
