Well, I finally pulled the tank off and set it up on my work bench for full drain testing. The result? I appear to be a bold faced lier!!!! The bloody things worked exactly as they should work!
Here is what I did: I set the half full tank on my work bench with the petcocks hanging over the end. I attached a length of clear hose to the fuel nipple and set it down in a 5 gallon bucket so I could see fuel flow rates. I then connected a length of 5/16" hose to my vacuum pump and then to vacuum nipple on the petcock (tested one at a time). The hose was loose by design as this pump is an industrial vacuum pump and it can pull a LOT more vacuum than the engine can, so I didn't want to hit the diaphram too hard and damage it.
As expected, when I hit the switch, the pump cam on and the petcock started flowing in "On". The second petcock responded exactly the same. So, I drained the tank down until I just had a tiny trickle coming out of the fuel nipple, then switched it to reserve, expecting nothing to change.
But, low and behold, the fuel flow jumped right back up where it should be! The other petcock behaved the same bloody way!!! I then tested both petcocks in prime and that too worked exactly as it should. I then left both petcocks on prime and let them run until they stopped flowing. There was only a few ounces of gas in the tank (barely enough to hear sloshing when I shook the tank). Again, exactly as it SHOULD work!
One thing I did notice is that I had to push the vacuum line up against the nipple and petcock to get a bit better seal on the vacuum line before the fuel would flow as fast in reserve as it did in prime, so that has me thinking.
So, here is where things stand:
1) The fuel filters looked a bit worse for wear. They have less than 15000 miles on them (1 1/2 years or so) and they did have a bit of sentiment in the bottom of each one. New filters have been installed.
2) The vacuum made me think. I am going to try and clean out the vacuum nipples on the carb boots to see if I have some blockage in there that is causing insufficient vacuum to be seen at the petcock. I'm also going to install new vacuum line, just to be sure.
3) I also picked up new fuel line, so I am going to replace all the fuel line before buttoning things up.
Then, I guess it is time to test reserve again and see if things actually work "under fire". If reserve doesn't work in use, then I have NO idea what is going on!
I would like to apologize for leading everyone astray. I did test those petcocks a couple of years ago and they did not work like they did today. Perhaps my testing methodology was incorrect.
to make them work?
