4. Turn the carburetor assembly upside down.
Measure the distance from the bottom of the
float to the float bowl gasket surface. See
figure 33. The correct height is 1.012 ± 0.04
in. (25.7 ± 1.0mm).
6. Adjust by carefully bending the tang on the
float arm (Figure 33).
NOTE; Both floats within the same carburetor must be at the same hieght.
CAUTION
The floats in all 4 carburetors must be adjusted to exactly the same hieght to maintain the same fuel/air mixture to all 4 cylinders.
7. If the floal level is set too high, the result
will be a rich fuel/air mixture. If it is set too
low, the mixture will be too lean.
in. (25.7 ± 1.0mm).
CAUTION
Ok. 2 questions, is there a second measurement for the other tang, and second, how can you adjust a float to create too rich a condition, unless its not shutting off and continually dumping fuel down its throat, the float doesn't determine how much fuel is being used, but making sure enough is available....and too shut off from overflowing
