The washer would be on one of the screws that hold the float bowl to the carburetor body. If the fuel level came up to the washer I think that's actually a little low. I scribed three marks (low limit/spec/high limit) on the carburetor bodies for my '80G and the fuel level should be a fine frog hair or two above the gasket parting line.
And I finally grok'd the 'pilot tunnel' as the hole drilled in the casting to connect the needle jets (emulsion tubes) and the pilot jet wells in the '70s and some early '80s style carburetor bodies.
So far I have run two sets of 81s on it, a set of 80 carbs, and a set of 79s I believe. I honestly never paid much attention to the needle jets or the emulsions as I have never replaced either in any of my carbs to date.
I am just going the easy way and so far it is working. I am not looking for max preformance or anything like that, just want her to run good there and all the way back home
