Front wheel bouncing
  • mmaddix
    • Jul 2011
    • 232
    • Beaufort, SC
    I was wondering if anyone has ever experienced the front tire/wheel bouncing, not wobbling, but bouncing at speeds around 80. It does it around 60 and 70 but you don't really notice it til around 80. And it's not just on one certain road.
    Thank you in advance.
    USMC 2005 - Present
    79 XS1100F -Mileage unknown - Clubman bars, aftermarket headlight and speedometer, 4 into 1 straight through exhaust, TopCat's fuse box, 1980G rear fender - Daily driver - My first Motorcycle
    78 XS1100E - Rebuilt And Sold I SHOULD OF KEPT IT!!!
  • ddragon63
    • Jan 2012
    • 1101
    • Ridgefield, WA
    new tire? old tire? just started having this problem?
    Don
    old:
    1989 kawi ex500
    1996 yzf-r6
    1999 yzf-r1
    2001 kawi zx-6r
    2000 Ducati 748
    2002 YZF-R1
    2005 V-Star 1100 Classic
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      Tire
      The tire is most likly way out of balance or out of round. Also the front shocks / forks may not be working properly, Oil. seals valving. many reasons for them not working right. I would change the fork oil and check the tire for round and balance 1st
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        • 3193
        I had a front tire seperate on a Toy run. It started with a bounce for a while then it got so I could not even ride it over 30Mph.
        The whole Toy Run slowed down and escorted me into town. Some then went as far as to ride me all the way home after too. It was a cool experience.
        Well back to the reason for the post...Check, recheck and check again the whole front end and tire. It could make all the difference.
        • ddragon63
          • Jan 2012
          • 1101
          • Ridgefield, WA
          last time I had 1 bounce I pulled into the gas station and checked the air... had about 5 lbs in it oops!
          Don
          old:
          1989 kawi ex500
          1996 yzf-r6
          1999 yzf-r1
          2001 kawi zx-6r
          2000 Ducati 748
          2002 YZF-R1
          • Lonerider62
            • Nov 2011
            • 187
            • Gaylord, MI.
            Maintenance
            From my own experience with the 80 SG I bought a few months ago (and which looked very good cosmetically), many of the original and second,third, etc. owners do or did very little regular maintenance on these vehicles. From the neck bearings to the rear gear box mine looked like it had seen zero regular maintenance once I got into it. I would recommend that you check everything. Right now you are concerned about wheel hop which could be anything from a tire that's coming apart to no damping in the front fork. If I were you, I'd get new tires, drain and refill the front shocks, check spring lenght etc. If, in fact it does have oil in the shocks but isn't leaking, your seals are probably OK. Then, check everything for signs of maintenance/do all the required maintenance and you'll feel better and know you are not adding insult to injury when it comes to the normal wear and tear on your bike. If you don't already have a manual get one, either on here or from the net. You'll be glad you did and have many answers at your finger tips
            Can't beat the smell of gas & oil
              I had a tire (the first tire I ever put on the front of my XS) that would bounce right at 70mph. I don't ride the freeway all that much so I didn't notice it very often, but it made long trips unbearable. It actually rattled the knobs off the radio in my fairing! I lifted the front wheel off the ground, and held it stable, then, looking just over the surface, I spun it slowly and could see a "fat" spot on it. Took it back to the place I bought it over a year afterward, and they replaced it for free - including installation. No problems with the replacement.
              • mmaddix
                • Jul 2011
                • 232
                • Beaufort, SC
                Their old tires and I just replaced the oil and seals in the forks a few months ago. I am buying tires later this month anyways because the back tire is so word you can see the cord/thread in the tire so I can't even drive it anyone til I get some new tires. I will see if that fixes it but if not I will try the other stuff
                USMC 2005 - Present
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  Tires
                  With tires like that, 99% sure you will fix your hopp with new "balanced" one's, good luck with your bike
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                    • 8077
                    Fabric showing? Bouncing? Park that thing until you get some new tires.
