Jet Needle
  • mack
    • 2411
    • Ontario, Canada
    Jet Needle
    So I thought I found one and ordered it. Had the same stock number and all.45214116-00 the number on the needle itself is 5GL-16. What came was completely different. So if anyone has one laying around please PM me.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • RODS454
    • Dec 2009
    • 83
    • Midlothian, Tx
    Jet Needle
    Can you post a picture, and what year model the carbs are? I might have what you need.
    "I'd rather be fishin'"
    1980sg "Cruise Missle"
    2002A Goldwing
    • mack
      • 2411
      • Ontario, Canada
      Needle
      Sorry it took so long, the only computer I can upload on crashed, just got it back.
      This is what I'm searching for. If you look close you'll see it has only one c clip setting . the number stamped just under the c clip slot should end with a -16. This is from a set of 81 carbs. If you have one, how much and what type of payment do you wish? Send PM
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
        Definitely looks to be an 81Special needle.......too short on taper to be the unobtanium 81Standard needle......
        • mack
          • 2411
          • Ontario, Canada
          maybe thats
          what I got in the mail. Whats the serial number on the standard needle. Maybe I have one.
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
            Don't quote me on this but think for the 81Standard it's 5IE26
            • mack
              • 2411
              • Ontario, Canada
              I'll check
              tomorrow and get back to you. If it is you can have it if you need it.
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
                Dentures for a hen
                Mack, the '80/'81 Standard carburetors use a Mikuni 5IZ7 (Yamaha part# 360-14116-07-00) needle but good luck finding one. Unless you've changed the intake and exhaust they work with the staggered 115 outer/120 inner main jets.
                The only new needles available are the Mikuni 5GL16 (Yamaha part# 452-14116-16-00 or a 3rd party knock-off) for the '80/'81 Specials and they work with the 110 main jets in all four carburetors.
                • mack
                  • 2411
                  • Ontario, Canada
                  Yep
                  Thats what I'm looking for and thought I'd ordered. I got something completely different in the mail. I haven't been able to find a source, even georgefix doesn't list them.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                    Thanks for correcting that 3-Phase.
                      Not a problem, 'man. We've both BTDTGTfrigginMikuniTS!
                      • mack
                        • 2411
                        • Ontario, Canada
                        Needle
                        Just a follow up. The needle I got in the mail has 5G4 stamped into it dispite the box being labled 452 14116-16-00/ 5GL -16. Not sure what it may be off, by the looks of it, probably a holly four barrel or something real big.
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
                          just a follow up. The needle i got in the mail has 5g4 stamped into it dispite the box being labled 452 14116-16-00/ 5gl -16. Not sure what it may be off, by the looks of it, probably a holly four barrel or something real big.
                          Mack, I dug up the gypsy spreadsheet with Mikuni needle dimensions I found online and it says that your 5G4 needle should have 5 adjusting slots so it's hard to say what you've got there.
                          If it's just a typo on the number of slots the 5G4 should be the same length as the 1980-81 5IZ7 Standard needle but a little thinner (richer) and with only one taper.
                          Code:
                          Mark	Slots	Length	Dist.1	Dia 1	Dia2	K1	K2	K3	K4	K5	K6	A1	A2	A3	A4	A5	A6
                          5G4	5	51.800	2.600	2.515	0.000	21.500	0.000	0.000	0.000	0.000	0.000	1.50	0.00	0.00	0.00	0.00	0.00
                          5GL16	1	51.000	3.000	3.000	0.000	16.800	20.800	34.800	0.000	0.000	0.000	1.45	3.00	7.00	0.00	0.00	0.00
                          5GZ6	5	52.500	3.000	3.000	0.000	17.200	39.200	0.000	0.000	0.000	0.000	1.45	8.00	0.00	0.00	0.00	0.00
                          5IZ7	1	51.800	3.000	3.000	0.000	16.800	34.800	0.000	0.000	0.000	0.000	2.15	8.00	0.00	0.00	0.00	0.00
                          Mack = 5G4
                          1980-81 Special = 5GL16
                          1978-79 All = 5GZ6
                          1980-81 Standard = 5IZ7
