simple question on small oil seepage
  • ddragon63
    replied
    Maybe oil pipe Seepage? only thing in that area is the lower cyl gasket and oil pipe
    Leave a comment:
  • ddragon63
    replied
    Talking right here buddy. Where the head and case come together under the carbs. its not a big leak but after a long hot ride you can find some oil out on the top of the side cases
    Leave a comment:
  • XS1100_OEM4ME
    replied
    Motor case/
    Are you talking the motor case behind the head, or Cyl case If on the motor case, is your PCV hose hooked up and clear to the air box?
    Leave a comment:
  • ddragon63
    started a topic simple question on small oil seepage
    So "old man" seems to seep a very small amount of oil... it collects ontop of the case behind the head... checking the torque on the head nuts is on my list of stuff to do (as lord only knows when they were last checked). I'm hoping this will make it go away. Any Thoughts?
    Can insert picture of area if needed
    Thanks guys
