I have a chance to pick up a 79 xs1100 special engine and wirering harness, but it has been sitting on a shelve for a few yrs. he won't give a price but says make him an offer. So what would an engine like this be worth? It is complete with carbs and everything low milage what he says, came out of a wrecked bike.
engine worth how much
My 2 cents: the carbs alone could be worth 100.
I would take a few tools with you when you go to look at it/pick it up.
See if the carb shaft moves and you can even reach in there and see if the slide needles move too.
If it's been sitting with fuel in there, those might be all gummed/crapped up and not move.
Take the timing cover off, use a wrench and see if it rotates. If you take the plugs out you can get a feel if there's some compression or not. Plus the plugs might tell you something too.
If that's all good, maybe $200 for the whole thing.
Again, that's what I might pay for something like that.
ps. Do a little research and check the numbers on the engine to see if is indeed from a 79. A 79 engine & Carbs are way different than an 80/81.Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather ride
If you take a battery and jumper cables with you, you can run a compression test. Pull the carbs off and squirt some light oil in each cylinder before testing, and if compression is good (180 psi + in each, within 10% of each other) I'd go $250 max. Also check for case damage, busted fins, etc if it's out of a wrecked bike.Fast, Cheap, Reliable... Pick any two
+1 on what Steve said. I didn't think about using the starter.
But hell yeah, if it's there spin that baby!Hi, my name is George & I'm a twisty addict!
The Green Monster
Got him in '04.
Scarlet
Got her in '11
Hugo
Cold weather ride
180 is pretty high, spec is 142.Life is what happens while your planning everything else!
Originally posted by DGXSER View Post180 is pretty high, spec is 142.Fast, Cheap, Reliable... Pick any two
Offer $100
You can always go up.
Hard to sell whole because of shipping cost.
But, you can part it out next summer & make out pretty well.(Unless you actually need it)Tom Clisham
79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
Steve, my first XS11 in good condition was about 150 across the board. Current one that sat for a few years was closer to 80, have not checked it since putting a few thousand miles on, but it runs pretty strong.Life is what happens while your planning everything else!
Don, I don't know what to tell you. The only one I've checked that had numbers at 'spec' was the motor that was in my SG when I got it, and that was only on two cylinders; the other two were 180 and 185. Well outside the '10%' range. Again, this is with the carbs removed and it should also be noted that the motors were cold. I suspect that 'hot' numbers may be lower, given the expansion you'll see in cylinder length, etc when the motor is at temp.Fast, Cheap, Reliable... Pick any two
They may be low for an engine that's been sitting on a shelf for a while, but the thing is: are they about the same on all 4? That's the big tell if all is well.
Like steve says, you can squirt some oil in there to help bring the numbers up if any of the rings are 'sticky'.Hi, my name is George & I'm a twisty addict!
The Green Monster
Got him in '04.
Scarlet
Got her in '11
Hugo
Cold weather ride
Spare motor
I paid $125 for a motor, carbs and airbox. They also had been sitting for years in a guys garage.He wanted the space back and I wanted the carbs. We settled on 125 if I would take the motor too.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186
12 degrees in Miami Florida?? Huh??!!Life is what happens while your planning everything else!
Cold
Originally posted by DGXSER View Post12 degrees in Miami Florida?? Huh??!!1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
Originally posted by GLoweVA View PostThey may be low for an engine that's been sitting on a shelf for a while, but the thing is: are they about the same on all 4? That's the big tell if all is well.
But, I'm no mechanic, just a dude with a wrench and a dreamXS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
