wiring harness
  • mack
    • 2411
    • Ontario, Canada
    wiring harness
    So I started cleaning the wiring harness today. I noted tape that wasn't the same as the rest, so I un-wound it and discovered several splices but this one, made me stop and puzzle, Has anyone seen this one in the harness before. The lump in the middle makes me wonder if is is not some sort of fusable link. Note that it is a solid white wire located just below the the "Y" at the D ring location. Cannot get the photo any clear"r unless I steal my daughers cell phone. Crap, paid big bucks for this camera 12 years ago and now they have better in cell phones free of charge. God I feel old.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Mack, that's probably the diode they used to 'convert' the AC to DC to drive the headlight relay. That white wire should be in one of the wires from the alternator and should go to the relay plug...
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      Diode
      That is the diode as Steve said. When I put my bike back together mine was bad. I got a Diode from Radio Shack could not find the value of it anywhere in documents. You can check it with OHM meter and most multimeters have a diode checker selection. It should show resistance in one direction and open when leads are reversed. If yours is bad you will not have headlight. The Radio Shack part number I used was 276-1114 and the white band (cathode side) goes toward the relay. Steve if you have any better info on what to use as replacement chime in. I could not find any info on the value. Mine has been running fine on the Radio Shack one I put in.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      Barnett Clutch Springs
      R1 Clutch Fiber Plates
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
      • mack
        • 2411
        • Ontario, Canada
        Ok
        I've found soooo much wrong with this bike I guess I'm getting a bit paraniod.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
        • GLoweVA
          • Jun 2011
          • 1957
          • Virginia Beach, VA.
          I currently have my headlight relay jumpered out. I think my diode might be bad. Now I know where to find it.
          THANKS!
          80G (Green paint(PO idea))
          The Green Monster
          Got him in '04.
          bald tire & borrowing parts
          Scarlet
          Got her in '11
          Ready for the twisties!
          81H (previously CPMaynard's)
          Hugo
          Cold weather ride
            Originally posted by ViperRon
            ...Steve if you have any better info on what to use as replacement chime in. I could not find any info on the value. Mine has been running fine on the Radio Shack one I put in.
            Any diode with enough current capacity should work fine. I can't imagine the relay coil drawing more than 100Ma (.1 amp), so most any will work if they're rated for that much or more.
            • cywelchjr
              XS-XJ Super Guru(Deceased)
              • 4450
              • Sacramento, CA
              The current level is pretty low, but make sure that the diode is rated for at least 14v or it will likely burn right out again. I forget off the top of my head the diode I used on my XS400, but all the Yamaha's that use the headlight relay with the diode external to the relay use the same diode and I just got something that I figured would most likely be at least 50% higher than original since I figured the original burned out, most likely from over heating meaning it was carrying more current than it liked. Being that I've repaired electronics for a living most of my life, and worked in R&D in the Army for a few years, plus designed a few circuits as a hobby, I felt safe in modifying it.
              • ViperRon
                • Feb 2011
                • 1062
                • Woodstock, VA
                Radio Shack diode
                Spec's for Diode 276-1114 pack of 3 Temp range -85 to 320 F, Peak inverse voltage 1000 V, Forward current 1.5A Peak surge current 50A, Forward voltage drop1.1V
                I am pretty sure this is overkill but itโ€™s a commonly supplied easy to get in stock diode and I used high amperage mainly to protect the circuits because it is directly in line with the alternator output. And if it goes out on a long trip to nowhere because I sized it too small people here will never let me forget it.
                Rodan
                1980 G Silverbird
                1198 Overbore kit
                Grizzly 660 ACCT
                122.5 Main Jets
                ACCT Mod
                Mac 4-2 Flare Tips
                Antivibe Bar ends
                Rear trunk add-on
                • mack
                  • 2411
                  • Ontario, Canada
                  Thanx Ron
                  You did a lot of work for me on this, I appreciate it. this harness has a lot of broken wires and patches poorly done. I worked on it all day and figure about two more to go before I'll install it. Have to get some shrink wrap and a few rolls of electrical tape tomorrow. Thanx again.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
