full engine re-build
  • Intelcamo1232
    • Apr 2011
    • 13
    • Chicago, Il.
    I noticed last year that the gaskets all leaked a good amount of oil at higher speeds, also that I wasn't getting the performance that I expected from this bike. Well I decided it's going to be a good idea to replace all of the seals and rings on the engine, give it all a good cleaning and try and spruce the old girl up. Any advice or input of any kind? I would greatly appreciate any at all.
    Thanks,
    Francis Livingston
  • old_skool
    • Nov 2011
    • 554
    • Ohio
    Personally, I'd find a good donor engine to run in place of the one your rebuilding, this way you can take your time, replace hardware with ss Allen's, polish all the cases, and if you need any parts to replace you'll have the time to search for best prices or machine shop if needed. JMO, unless you have something else to ride or not worried about it, but you can usually source entire donor bikes fairly cheap, and sell off parts not needed to offset cost of donor and repairs. Oh, and you could always inspect or do the second gear repair while its out also!
    Get a manual if you don't already have one.
    81 XS1100H
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      Parts
      New parts can be a PIA to find. You can find rod and main bearings on Ebay most of the time, but$$$. The rings are the hardest parts to find new, not know of any stock new out there anymore. Before you do a complet teardown, check the compression, if in spec, you can reuse the rings you have if needed. Also, if good compression, I would check and see why no power There are many things that cause these bikes to run poorly, running on 3 cyls happens often, poor carb adj, cleaning, weak coils, valve adjustment etc. If you have good compression and low preformance, a rebuild probly wont help much, JAT
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
      • ViperRon
        • Feb 2011
        • 1062
        • Woodstock, VA
        Rebuild
        Before you start as suggested by SX1100_OEM4ME I would do the basic checks on engine compression valve adjustment checks etc. You may find a simple problem and save a lot of money and aggrivation. I by bought new parts for mine some time back and they are not cheap. I would recomend looking for an engine here on this site or EBAY. Just rings when I got mine were 130.00 and I got a discount. When you get ready to clean up the engine I would do it like XSive Maximus and not paint the engine. I painted mine with a high temp clear and wish I had not. If you take the time to polish up the engine like I did and then the head starts to yellow you will be pissed. If you need any help first check the FAQ and then ask we will help.
        Rodan
        1980 G Silverbird
        1198 Overbore kit
        Grizzly 660 ACCT
        Barnett Clutch Springs
        R1 Clutch Fiber Plates
        122.5 Main Jets
        ACCT Mod
        Mac 4-2 Flare Tips
        Antivibe Bar ends
        Rear trunk add-on
          As was said, rebuilding one of these isn't something you do lightly. Rings aren't too bad to find usually (here's a set for $80...http://www.ebay.com/itm/YAMAHA-XS110...sories&vxp=mtr) but pistons/bearings are expensive and very hard to find (figure about $800 ). As far as sealing the motor against leaks, as long as it's not leaking at the head or base gaskets, most gaskets can be replaced by Yamabond sealer and the few seals needed (and still available) can be purchased separately. If you need to pull the head, then buying a complete gasket set will be cheaper than buying a head gasket by itself; PartsNMore will have the gasket set for about $90.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Good find!
            That is a good find CS! While not OEM, should be fine and a good price The last time I did a complet overhaul, had to hunt and spend$$ to get the OEM rings. I sold a complet set of rod and main OEM bearings (all colors and complet) for $75.00 this past year, needed the money
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
              On the crankshaft bearing shells, I remember someone saying just to use the blue color (tightest) shells with a used smooth crank and you'll be OK. Not that those are any easier to find, YMMV
                Just to add, the crankshaft journal bearings are readily available, as the FJ1100 + 1200 use the same shells as the XS11 with the exception of that one oddball half shell.
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  Fuel
                  Blue is best, especialy if you plan to wash out your motor a few times with fuel like I did
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
