G'day from Down Under,I've just got my first xs11 and electricory aint my strong point. Its about them dam indicators / flashers again!.  My 78 1100e is an OZ model and we dont have a front driving light set up like you guys do .The front indicators / flashers on OZ models only have 2 wires and the head light is on a seperate switch that can be turn off completely.Now my problem is when I turn the headlight on, even in the park posisition the front & rear indicators / flashers glow.Whats with that ? & how can i disable this ?. I need to rego the bike and in OZ the ind /flashers are only used to indicate your intention yo turn.Also what is the reserve lighting device for?.There is also a box just behind the coils with upper on it what with that ? and just below the coils to the left is a little module with 2 red wires ,what is this.Also left of the fuse box is a single fuse with 2 wires that run into the main harness what is this 4.Sorry for my ignorance,but you can probably tell i dont have a w/s manual 4 the bike (hard to find)    Any help/advise would be welcome as i want to get on the road as soon as possible (the weather is great at the moment.)
	 In the end I disconected both front turn signal earth wires inside the headlight shell & ran a new earth wire
 In the end I disconected both front turn signal earth wires inside the headlight shell & ran a new earth wire  It all works perfectley.
