emulsion tubes
  • mack
    • 2411
    • Ontario, Canada
    emulsion tubes
    Haven't found anything in the books with regards to models and tube numbers. I have a few here, some are 300-x2 and some are 266 x2 and I'm sure there is more, as, if I remember correctly, 2&3 on my SF were different from one and four. Anyone have some insight on these. Trying to figure out if PO had changed the emulsion tubes to account for using the wrong jet needles.18's instead of 16's with the 300 x-2 tubes.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Mack, I don't have a '81 FSM so I can't tell you what should be in there. But my understanding is the tubes and needles need to be 'matched' in order to get the right mixture at a given throttle opening.
    • mack
      • 2411
      • Ontario, Canada
      Yea
      That would be my understanding as well Steve. Just can't find out what number of tube match what needles.
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
      • SFerinTEXAS
        • Jun 2006
        • 877
        What model carbs are you repairing? With the vent tees or without.
        79SF
        XJ11
        78E
        • GLoweVA
          • Jun 2011
          • 1957
          • Virginia Beach, VA.
          According to the parts fiche, in the 81LH, all 4 carbs have the same emulsion tubes and needles, so, there shouldn't be any mismatched parts in there.
          Some of these bikes did have different jets in 2 & 3 to richen them up a bit to keep them cooler, but again, according to the 81LH fiche, you should have all 4 the same.
          Maybe the PO put 2 different carb sets together and that's why those internals are different.
          Sounds like you've got a good mystery on your hands.
          EDIT: Just looked at the SF fiche and saw that those carbs do have different tubes in 2 & 3, but they do have all 4 the same needles and jets.
          Here's a link to all the Yamaha's fiche's:
          http://www.ytcn.nl/archief/index.php...L%201950-1996/
          80G (Green paint(PO idea))
          The Green Monster
          Got him in '04.
          bald tire & borrowing parts
          Scarlet
          Got her in '11
          Ready for the twisties!
          81H (previously CPMaynard's)
          Hugo
          Cold weather ride
          • mack
            • 2411
            • Ontario, Canada
            The
            problem is the needle jets don't match the carbs. Steve and I both agree that the needles should match the tubes. What I'm trying to figure out is if the PO changed the tubes or just used the wrong needles. I went through the fishes today for every year but had little joy,then went to the vintage parts store. They had one needle in stock that will work, at least match the correct needles but I still don't know if I have the correct tubes. Will pull one of the original carbs apart tomorrow and check the tube number. If they match then I've wasted everyones time with this ridiculous issue. Why the PO put the wrong needles in will remain a mystery but may expalain why he parted the bike out. Yikes!!!! It just ocurred to me that I bought the head too. Hmmmmm. wonder what goodies that will yield.
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              • Fort Myers, Florida
              Kits
              There are so many carb kits that "claim" to have the right parts for different carbs. It is hard to tell what the PO bought or got and tried to use in those carbs? Many PO's get expert advice fromt their mech. friends and we end up trying to sort it all out Good luck with yours
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
                • 8962
                I've run into one set of carbs (late BS34-III's) that had wrong needles and tubes in there, the transition between pilots and mains couldn't be properly tuned, ran like POS. Put what is supposed to be in there and you really can't go wrong. Then you can figure out what jets you need for your application. JMHO, been there before.
                • mack
                  • 2411
                  • Ontario, Canada
                  Yep
                  That's what I'm trying to do. Will advise tomorrow what the originals had in them.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                    Jet Needles and Needle Jets
                    Here you go, Mack. These are the jet needles and needle jets from an earlier thread that I hope will help:-
                    Jet Needles
                    Needle Jets
                    The whole thread:-
                    Help Find A Cure for Crazcnuk's bike?
                    • mack
                      • 2411
                      • Ontario, Canada
                      Beautiful
                      Thanx 3 phase, thats what I needed. Saved me some time in the shop for sure.
                      mack
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      613-398-6186
