carbs
  • mack
    • 2411
    • Ontario, Canada
    carbs
    Back still isn't too good yet so I haven't been able to bend over Spica to finish her but I did spend some time sitting at a table putting a couple banks of carbs back together. I'd purchased a set and had them delivered by snail mail. When they arrived, I found them damaged.
    You can't really see it in this photo but the throat is actually out of round.
    I wasn't too worried about the inside other than having the piece come loose and pulled into the motor, I was more concerned with getting a proper seal in the manifold. Took it to a friend with a tig welder and he made the repair and put it back to round.
    Of course it had to be number two carb but I think it will be fine now. I also noticed that on the number four carb a piece of the lip around the bowl seat is broken off as well. About a half inch missing but I doubt it will cause any problems. The post office wonders why they are losing business.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Look nice
    He did a nice job I use a small tail pipe expander to true up out of round stuff, bit that was damaged and looks new now, good luck with your bike and a prayer from me for your back pain cure
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
