Detrimental to my health
  • Rasputin
    • 3189
    • Lacombe, Alberta, Canada
    I have brake rotors off an 81LH that I want to repaint. Can I safely use a sandblaster with 220 grit aluminum oxide sand to remove the existing paint? Will the sandblaster over spray damage the rotor? I do not want to end up with grabbing brakes that will be bad for my health. I tried it on an old brake rotor I have handy and it looks ok and mic's out within spec after doing it. I guess I could use some kind of tape that would hold up temporarily to the sand, but if it fails....well you know the picture. Thoughts, Yays, Nays, all appreciated.
    2-79 XS1100 SF
    2-78 XS1100 E Best bike Ever
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    I wouldn't
    I wouldn't, the rotors are not ment to be turned so I wouldn't blast the brakeing surface. If you do, the pads will polish it back in time with some use, at the expence for wearing down you pads faster. You can easly scotch bright the black centers for repainting them, then cut a whole the size of the black part of the rotor, in a big pice of cardboard to cover the braking part of the rotor to paint it
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
      • 7817
      Didn't I read someplace that it was OK to work the braking surface with garnet paper and garnet paper only? Aluminum oxide will imbed in the rotor.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Yes
        Yes, I am talking scuffing the painted center to get it to hold paint better, I wouldn't do anything to the braking surface of the rotor
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          • 7817
          Here's what I think. Bear in mind what I think might not be worth a ---.
          Go ahead and blast them in the center if you want to. When you're done work the braking surface very well with a block and some 100 grit garnet paper. That sanding should get any aluminum oxide, as well as remove whatever your brake pads have left behind.
          If it was me, I wouldn't bother with the blast cabinet, but rough up and clean the center as suggested by others. I'd work the braking surface with the garnet paper anyway.
            • 8753
            I have removed the center paint from the rotors on my 79 Special with no ill effect. I have also scuffed the braking surface with 100 grit to remove glaze with no ill effect. They are not that delicate, JMHO, YMMV
            • ViperRon
              • Feb 2011
              • 1062
              • Woodstock, VA
              Brake rotors
              My Rotors front and back had issues where they would shutter. I used a micrometer and could see differences in the thickness in the rotors. I have a lathe and milling machine so I turned mine down and final polished to a factory finish. They seem to work great now but I did not remove much surface metal. I would not advise this just to remove wear and scratches in the rotors as they will eventually return.
              Rodan
              1980 G Silverbird
              1198 Overbore kit
              Grizzly 660 ACCT
              Barnett Clutch Springs
              R1 Clutch Fiber Plates
              122.5 Main Jets
              ACCT Mod
              Mac 4-2 Flare Tips
              Antivibe Bar ends
              Rear trunk add-on
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                I will go with that
                Phil has had much more experance with these bikes then I, and been a big help to me and others, so, If it worked well for him, should do the same for you
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
