Paint your carbs?
  • old_skool
    • Nov 2011
    • 554
    • Ohio
    Paint your carbs?
    I've heard of people painting their carbs and some even say not too. Who here has and have some pics of their finished products, whats the pros and cons. I'm going to try soda blasting mine, I'm polishing the bowls and vacuum covers, but not sure which way I want to go with the bodies. Is there a special type of paint? what kind of prep would be needed? Thanks! Really looking forward to seeing someone elses results.
    81 XS1100H
    The midnight special carbs came black from the factory, so it is possible.
    Prep would be no different than any other aloy paint prep work. Obviously you would need some paint that was gas proof but I would probably go with powder coating if I were going to do it personally.
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      Carbs
      I detail paint mine, the bodies and trim, then polish the tops and bowls and use new S/S hardware. Yamaha coated the carbs on the MNS so I don't see a problem, just mask off "EVERYTHING" you don't want paint on / in
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
      • old_skool
        • Nov 2011
        • 554
        • Ohio
        Nice detail work, how/what technique did you use to clean those carbs so well...or is that silver paint?
        81 XS1100H
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          Carb paint
          And , yes, the top braces are on backward in the pic's, I turned them around befrore install Use a light coat of self-etching primer, then two light top coats of the color of you like with a good motor paint. I clear coated the polished parts to keep from tarnishing
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
            I paint mine with a small brush and high temp silver when they are on the bike. I just do the outer two that are visible. They look pretty good and are easy to touch up (5 minutes). Yeah I know the top screws are rusty, they have SS now.
            • old_skool
              • Nov 2011
              • 554
              • Ohio
              Originally posted by XS1100_OEM4ME
              And , yes, the top braces are on backward in the pic's, I turned them around before install Use a light coat of self-etching primer, then two light top coats of the color of you like with a good motor paint. I clear coated the polished parts to keep from tarnishing
              I noticed they start to tarnish pretty fast after polishing them, I was thinking of using Mothers aluminum polish afterwards, but the clear coat would be a lot easier and less follow up maintenance, how does it hold up?
              81 XS1100H
              • DAVINCI
                • Jan 2011
                • 1048
                • Cedar Mountain, NC
                I went a completely different direction. Duplicolor Metalcast. It's a two-part coating. I think they have three or four colors. No problems with fuel, but then my carbs don't leak . The stuff does chip easily, though. It's more brittle than any other paint I've ever used.
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  Clear
                  I like it especialy on the carbs because they are a PIA to get too to wax, they lose a little of the "chrome" look, but here close to the beach in Florida, the "chrome look" doesn't last long Eastwood has one just for bare metal, but others might work just as well I did my whole motor case covers also, here is how it looked, this was before carb, valve cover, tank & sidecover paint
                  This is after carb paint
                  You would be suprised how many complament on the carbs, especialy when I tell them the bike is 33 years old
                  http://www.eastwood.com/ew-diamond-c...ero-11-oz.html
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    Davinci & Phill
                    Nice work to both Davinci and Phil I love seeing these antiques looking better then some guys two year old bikes
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                      I'm a powdercoat user....
                      [IMG][/IMG]
                      ... but this requires complete disassembly of the carbs to do.
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        Brass plugs
                        What did you use for those brass looking plugs, NICE
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                        • XS1100_OEM4ME
                          • Mar 2009
                          • 1619
                          Bits and pieces
                          Here are all the bits and pieces painted and back on the bike, and yes, it does need washed and detailed
                          1980 XS1100 Special
                          1990 V Max
                          1982 KZ750 LTD Twin
                          1974 CB750-Four
                          Past/pres Car's
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            1979 again
                            From a distance, you would almost think it is 1979 again How I wish it were true Nostalgia
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                            • DAVINCI
                              • Jan 2011
                              • 1048
                              oh, man, you wouldn't believe me if i told you
                              Thumbtacks
