Coils
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Coils
    OK, not a rocket scientist here but, I have OEM coils, my understanding of coils is two windings of wire around a conductor in a heat sink of some kind? One is a charge coil, small # of windings, the other is a discharge coil, large # of windings. So, my question is, if both windings are intact, how is the efficiently changed Is it more the grounding, or old ign wire's, or what. I don't want to spend $$$ now, but would rather get my current OEM coils working up to standard, any thoughts
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
  • Lonerider62
    • Nov 2011
    • 187
    • Gaylord, MI.
    I found this site today when I was trying to get some better info on why we see different types of coils and ignitions. It's on the long side but a good read that will enlighten most people on how our ignitions, and others, work and why.
    Can't beat the smell of gas & oil
      The usual problem is that the insulate separating the two coils degrades and then the two sides of the coil short out internally. Or the wires degrade and the circuit opens and current no longer passes through the wires.
      Other than cleaning up all the connections before thw coils and putting new plug wires in there is nothing else you can do except replace the coil.
        You can also have issues with the spark plug wires' connection internally on the coil, as well as bad wires. Some guys have had success replacing the wires, but it's a bit of a PITA.... look here: http://www.xs11.com/forum/showthread.php?t=137
        This isn't something I would recommend, but it is a possibility. But as Nate said, if the coils are failing, the coil is toast....
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          So
          So, if I have this right, it is the internal coil of wires that lose there insulation and short inside the windings that cause the breakdown of output i would guess over heating would cause this over time Mine both work, but I have seen two plugs on one coil seem to foul quicker then the other two. I will break down and buy new coils and wires soon, just hate to keep throughing $$$ at it, I didn't care when they $$ seemed to grow on trees
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
            There's a number of things that can cause reduced output; yes, if the primary and/or secondary coils internal to the coil start to go bad, that will cause reduced output. That's easy enough to check; simply put an ohmmeter across the two windings and see if they meet spec. The primary windings should check between 1.35 and 1.65 ohm, the secondary should be 12-18K ohms; above or below these numbers means a failing coil. It is important to check the secondary winding with the spark plug ends removed; those ends are supposed to be 5K ohms each (+/- 10%). These simply unscrew off the wires, and are known for poor connections where they screw in. If any ends check out of spec, replace them; they're cheap enough at about $3-5 each. With the ends installed, you should see no more than about 29K ohms across the two plug wires.
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              plug ends
              Yea, I have all new ends, NGK 5 ohms, did the 1/4" clip on the wires. The bike runs OK, some poping, not much now that I turned the mix screws out 1/4 turn (thanks Phil on both the mix screws and plug caps) I just have two plugs that foul quicker then the other two 32 year old coils / wires $$$$ in my future, not much else I haven't replaced
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
                2 and 3 by any chance?
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  2 and 3
                  Yes it is, have an idea
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                    Those 79 Special carbs have "richer" emulsion tubes (less air mixture holes) in the center two carbs to try to keep those cylinders cooler. Just thinking maybe that's why the plugs look darker.
                    • XS1100_OEM4ME
                      • Mar 2009
                      • 1619
                      Thanks
                      Thanks, I did not know that I am not sure I put them back in the right carbs as I soaked them all over night in one container, then reinstalled everything, thinking they were all the same, I will check the next rebuild
                      1980 XS1100 Special
                      1990 V Max
                      1982 KZ750 LTD Twin
                      1974 CB750-Four
                      Past/pres Car's
