I have a stock 1980 XS1100SG, and thanks to this website and the members who always are willing to help I was able to restore my XS1100 and have been riding it for the last year. Put 4000 miles on it. Now I have a new problem and need your help. Slowly my XS1100 started fouling. On several occasions while I was riding down an expressway I would loose power but after awhile it would start operating normally. I checked my plugs and I was not getting any spark on cylinder 2. I rewired the coils and fixed the spark problem. Started the XS1100 and it worked fine for about 5 min. Then it started knocking loudly. Now I have no compression on piston 2. The spark plug anode is shorted with the tip of the plug. I guess the piston hit the plug. The piston is still moving up and down. I am guessing maybe the piston has a hole because there is no compression.
Any ideas what might be the problem? I am not a mechanic but I am handy with tools and mechanically inclined. I think I could fix the problem with a little help of my friends on this forum.
I will remove the head and check to see how bad the damage is. I shut the engine down real quickly when it started knocking. If it is a broken valve and the piston is ok do you think the engine would be repairable? I love my xs1100 and will teardown and rebuild the engine myself. I am no mechanic but I sure will give it a shot with a little help from my friends. This will be my winter, spring, and summer project. I don’t know if I can find the parts I need to repair the engine. I do know I could probably find a gasket set for the engine online. I would appreciate everyone’s thought on this.
