How fast am I going?
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    So I come out from work today and here's what I find.
    My needle broke!
    Argh.
    I guess it's time for some kind of replacement.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    Good time to find a 160 MPH unit. You probably went too fast and broke the needle.
    • jwhughes3
      • 2798
      • Home of the Alamo
      Paint
      Just paint an orange line across how fast you generally want to be going.
      Problem solved.
      John
      '81 XS1100H - "Enterprise"
      • GLoweVA
        • Jun 2011
        • 1957
        John and Phil, you guys are funny!!
        The weather got COLD a few days ago and it started making this kinda squealing noise. I thought it was just the cold making act up. (I kinda remember it doing stuff like that before last winter)
        So, I have (on a few occasions) exceeded the 85 on the dial, but not by much.
        I guess 31 years and over 82,000 miles its time was up.
        So, not only am I looking for a new speedo, I also need a needle for my 80SG tach.
        The search begins....
        The Green Monster
        Got him in '04.
        Scarlet
        Got her in '11
        Hugo
        Cold weather ride
          There's still enough needle there George...........imagination for the rest......plus now if u want the bike will go faster than 85 and you can go ahead and use 4th and 5th gears.......
            If you want to go really fast, find one of those 220 kph Canadian units.
            • petejw
              • 2269
              • sydney australia
              hey phil,
              our ones over here go to 240km/h,
              now if only my bike was red,
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • GLoweVA
                • Jun 2011
                • 1957
                Which one to get ????
                240km/hr ?!?!? I think my bike would fall apart at that speed and I'd probably need 1.21 jigawatts of power to make it go too.
                Alright you guys.... You're funny.
                Seriously, are all the standard (78-81) speedos compatable? Plug and Play?
                How about one from an 850/750/650 ?
                Just trying to broaden my search criteria that way I know what will work and what won't.
                Thanks for the laughs.
                The Green Monster
                Got him in '04.
                Scarlet
                Got her in '11
                Hugo
                Cold weather ride
                  I am almost certain that any year or model XS11 tach and speedo will interchange from a wiring aspect. Of course, if you go round from a special instead of the square form a a Standard you will most likely need to do something with the mount.
                  And BTW, be very carefull with those Jigawatts of power, If you get all that and break 88 MPH I hear folks from Virginia have made it back up to 1985!!
                  • jwhughes3
                    • 2798
                    • Home of the Alamo
                    Compatible XS speedos
                    If its from an XS its compatible. The speedo gears are same in all and I know some run a speedo from an XS400 or 140 mph from a 750/850. If you use one from 400 you need whole assembly since they had no square standard style.
                    John
                    • guycom
                      • Nov 2011
                      • 13
                      • Sea Bright, NJ.
                      Gps Maybe
                      Most GPS units tell you your current speed and you also get gps functions, often found for under 100 bucks.
                      Guycom
                      • clcorbin
                        • Jan 2010
                        • 495
                        • Albuquerque, NM
                        That cold did it in. If you heard a squealing noise, the rotor and cup was touching very slightly. I've seen them grab in these situations, which causes the needle to be very violently jerked around, leading to it breaking against the stop. My old speedo did pretty much the same thing last winter. Strangely enough, I have a "new" gauge cluster on my bike today...
                        And it doesn't help that after 30+ years of UV, oxidation and vibration the plastic needles are about as brittle as they can possibly be. I'm kind of surprised that flash photography doesn't break more of them from the extra photons hitting it!
                        -- Clint
                        • GLoweVA
                          • Jun 2011
                          • 1957
                          Update.
                          So it got colder the last couple of weeks and wouldn't you know it, the whole thing grenaded on me!
                          I'm riding in to work, (about 30F) and it's squealing a little and working okay, (if you can figure out how fast by looking at the nub)
                          and next thing I know, the whole thing is spinning around like the second hand on a stop watch. (Just faster)
                          Okay. At least the Odometer is still working and I can use it to see how far I've gone. (for tank fill ups)
                          Riding it home from work that day and next thing I see is that it's all black on the odometer numbers. (can't see them any more.) It's like they're covered in graphite or something.
                          (I think, this is bad.... I look at the numbers and they're rotating backwards!
                          Like I'm going in reverse or something.
                          So, now I've got less miles on my bike when I get home than I had when I left work.
                          Weird part is, the self cancel signals still work. I guess that little reed switch in there is 'upstream' of the speedo/odometer gears which are now TOAST!.
                          Time to save up some $ for the replacement.
                          At least I can use the Tach to judge/guess at how fast I'm going.
                          The Green Monster
                          Got him in '04.
                          Scarlet
                          Got her in '11
                          Hugo
                          Cold weather ride
                            Use the tach for speed idicator.........got for practice anyways........4K is 60mph in fifth.....bout 62 for the Standard......5K rite at 75 on the Standard, so on and so on. Was a chart on here many years ago for calculations, but haven't a clue of thread title now......slept since then, plus CRS...........
