Banjo Bolt
  • mack
    • 2411
    • Ontario, Canada
    Banjo Bolt
    Any one have the length of the bolt that connects the two front brake lines to the Y, on a 79 SF. This is the longer one with two holes.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • old_skool
    • Nov 2011
    • 554
    • Ohio
    depending on soon you need this info, I may be tearing mine apart in the near future and can measure/take a pic for you. Working on carbs and a few other items at the moment.
    81 XS1100H
    • SFerinTEXAS
      • Jun 2006
      • 877
      Sitting here being armchair lazy I would suggest you measure a short one and add to it the width of another hose banjo and 1 seal ring. Or wait . Sooner or later someone will pipe up.
      79SF
      XJ11
      78E
      • SFerinTEXAS
        • Jun 2006
        • 877
        Got unlazy went to boxoparts , grabbed a dig caliper and here goes.
        29.79mm or 1.173 in shank length . Dang dig caliper, every time I measure it the last digit on these figures change a little up and down .should be close enough.
        79SF
        XJ11
        78E
        • mack
          • 2411
          • Ontario, Canada
          Thanx
          You the man.
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
          • DAVINCI
            • Jan 2011
            • 1048
            • Cedar Mountain, NC
            Simple.
            It's a double banjo bolt...duh!
              • 2117
              I think i have a new one if you still need this.
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                • Fort Myers, Florida
                Bolt
                Is this what you need?
                http://www.boats.net/parts/detail/ya...-10044-00.html
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                • mack
                  • 2411
                  • Ontario, Canada
                  Got it
                  Thanx guys but I got one. The book showed three available lengths in 10 mm. I've converted the LH braking system to that of a 79 special so thats why I asked for the measurement.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                  • SFerinTEXAS
                    • Jun 2006
                    • 877
                    Glad you found it. I'm keeping that option open on my XJ but for now I'm kinda liking the linked system since its working well.Not trying to start another "VS" discussion.If anyone wants to they should find the older threads and add to those.
                    79SF
                    XJ11
                    78E
                    • mack
                      • 2411
                      • Ontario, Canada
                      proportioning valve
                      There was a serrated washer and some brass inside mine that didn't look too healthy. I couldn't find replacements and didn't want to chance a failure. I really don't like the concept either. Thats why I swapped.
                      mack
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      613-398-6186
