Curious oil consumption incident..!!??
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    About three weeks ago I got caught in a traffic jam caused by an accident. I barely moved 1/4 mile in about 15/20 mins. I started getting worried because I could feel the bike getting very hot. I did some lane splitting but since it's illegal in FL I didn't want to get caught either, so I worked my way over three lanes so I could do a u-turn and take another route home.
    As soon as I made the U-turn I could tell the engine wasn't happy, so I just babied it until I could get some airflow going and cool the engine back down. It made a little knocking noise but it went away right away as I got underway.
    The next day during my routine inspection before riding the bike I noticed the oil level was low..!!!! I topped it off, it needed 1/3qt.
    This is a very strange occurrence because this bike NEVER consumes oil, and I've put maybe another 200 miles on it since then with no change in the oil level and no oil required..???
    Does anyone know, have any ideas, what would have caused this???
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
    My best guess would be if it got hot enough, some clearances moved around some and that coupled with the thinned-out hot oil allowed some oil to get places it normally didn't get. Short answer, it burned it. A oil cooler will help with this by keeping oil temps down. You might want to change the oil, as that no doubt accelerated it's breakdown....
    • Cobia
      • Jul 2007
      • 1587
      I agree about changing the oil ASAP due to thermal breakdown, thanks. Funny thing was that I didn't see any smoke either, and I looked for it after I got underway again. Weird !!!
      I do have an oil cooler I bought to put on it, but my Kerker exhaust prevents me from installing the SOFA/adapter i got from TC. I do have a 4X2 Jadine spaghetti turn out exhaust that will allow me to install those items but BikerPhil discouraged me from installing it because of the heat generated by the pipes that would run under the pegs... !!!!
      Kerker 4 - 1
      850 Rear End Mod
      Automatic CCT
      '82 XJ1100 (Sold)
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        • Fort Myers, Florida
        Wow
        Wow, 20 min with no air running across the motor in Florida A big +1 on changing the oil and filter. Oil will burn up and break down in those kind of temps I would keep a close ear to make sure none of the valves warped at all, any new noise would require investagation before many miles to avoid dropping one I would also check the new oil and change it as soon as it starts to get dark, 1000 miles tops, as it wil be picking up any burnt oil still in the motor
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          I know mine rarely used oil, but if ran hard in hot weather it would use oil, sometimes quite a bit. I recall a trip I took in eastern Washington one summer, and after running at high speed across the desert near the Hanford reservation in 100+ temps, the bike ate a full quart of oil in the space of one tankful of gas. Got back into cooler temps, and the oil use went away....
          • James England
            • 3039
            • North of England
            Oil cooler
            The European XS1100's came with an oil cooler as standard. They do dissipate heat when the bike is stationary, via the black feed pipes and the radiator itself. Having said that though, the oil cooler is designed to have air flow through it in order to work really well. It certainly will do no harm to have one but I don't think it's a wonder solution to the bike remaining stationary in the sort of temperatures in some parts of the USA which we never see here (or rarely) in Europe.
